t3/t4 spool up?
Old Mar 6, 2007 | 08:39 AM
cleanej2's Avatar
Default t3/t4 spool up?
at what rpm do they spool up at
Old Mar 6, 2007 | 08:41 AM
Autoworks's Avatar
Default Re: t3/t4 spool up? (cleanej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 &raquo;</TD></TR><TR><TD CLASS="quote">at what rpm do they spool up at</TD></TR></TABLE>
the unanswerable question
somewhere between 500-6500RPM
Old Mar 6, 2007 | 08:44 AM
cleanej2's Avatar
Default Re: t3/t4 spool up? (Autoworks)
lol why is it unanswerable
Old Mar 6, 2007 | 08:45 AM
Dunc's Avatar
BCICAN
Because basically 95% of all turbos are classified as a T3/T4.
Example:
T3/T4 .48 trim
T3/T4 .57 trim
T3/T4 .63 trim
T3/T4 60-1
T3/T4 62-1
Old Mar 6, 2007 | 08:46 AM
Azn Kenny's Avatar
And it also depends on what motor it's on...
Old Mar 6, 2007 | 08:53 AM
cleanej2's Avatar
Default Re: (Azn Kenny)
what trim should i use if i want a spool up at around 3500 on a d15b7
Old Mar 6, 2007 | 09:46 AM
tweekerz's Avatar
Default Re: (cleanej2)
I think the T4 compressor is a bit large for you. Maybe a T3 or a GT28 would be good for ya.
Old Mar 6, 2007 | 11:26 AM
Schister66's Avatar
Man U FTW
Here are some questions to answer for us before we can make any kind of guess at what you want/need.
1. What engine?
2. What are your goals?
3. What do you plan to use it for (strip/street/autoX)
4. What is your budget?
5. What does the rest of your setup look like?
6. What kind of powerband do you want? (ties into #3)
After you answer those, we can give you a pretty good idea of what to recommend.
Old Mar 6, 2007 | 02:36 PM
integra racr04's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Here are some questions to answer for us before we can make any kind of guess at what you want/need.
1. What engine?
After you answer those, we can give you a pretty good idea of what to recommend.</TD></TR></TABLE>
not sure about the OP, but im runnin a B18B Daily driven DC4 with the occasional track use, lookin for somewhere around 250whp, lookin to spend about 2500-3000...would u recomend a kit, or something i can piece together??, can anyone help me?
Old Mar 6, 2007 | 02:42 PM
b18sihatch's Avatar
Default Re: (integra racr04)
really depends on if you are looking for quality parts, a used quality turbo kit can run you into the price you are looking to spend
and a pieced together quality kit can also run you into the same ammount of money.
so really its either or, but with a pieced together kit you can pick and choose different parts that a kit wouldnt come with.
but IMO full race makes the best kits that are available period be it stage 1,2,3,4,ect
Old Mar 6, 2007 | 02:58 PM
sc4dr's Avatar
Default Re: (b18sihatch)
Check out Peakboost, and AFI too
Old Mar 7, 2007 | 02:23 PM
cleanej2's Avatar
1. What engine?
i have a d15b7, its my daily driver n i just want a little more power than i have maybe like another 50whp or so, if its possible i'd like to spend around 500, i just have the basic bolt ons rite now
Old Mar 7, 2007 | 02:46 PM
Soccerking3000's Avatar
get a t25 or straight t3, a t3/t4 is way to big for your goals
Old Mar 7, 2007 | 02:53 PM
Schister66's Avatar
Man U FTW
Get a 14b, smic, DSM440s, DSM bov, oil line kit, HF manifold and adapter plate, SAFC, and connect it to your stock exhaust. There is more to it, but thats a good start.
Old Mar 7, 2007 | 05:13 PM
Mugencrxsir1's Avatar
Yeah turbo is nice for a little extra kick, but for 50 extra ponies? You might want to look into nitrous if you only want any extra 35-50hp.......Just a thought!
Old Mar 7, 2007 | 05:14 PM
Schister66's Avatar
Man U FTW
you're looking at a possible 100whp gain....most people stay around the 220whp range on stock D's
Old Mar 7, 2007 | 06:52 PM
cleanej2's Avatar
where can i get one of these small turbos.. id prefer a used one just to save a little money cuz rite now im payin for an accident that i got into in the rain
Old Mar 7, 2007 | 08:24 PM
95GSRTT
Guest
Posts: n/a
you will regret going turbo with having that much of a limited budget. Something WILL break or go wrong and you dont sound like you can afford that.
Old Mar 7, 2007 | 08:25 PM
Schister66's Avatar
Man U FTW
Default Re: (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">you will regret going turbo with having that much of a limited budget. Something WILL break or go wrong and you dont sound like you can afford that. </TD></TR></TABLE>
its a sad fact, but i agree....cheaping out never ends well
Old Mar 7, 2007 | 08:30 PM
dezerte's Avatar
If you want to spool at around 3k-3.5k with a B18b with stock and make ~200-220whp one should go for a GT28 turbo?
Old Mar 7, 2007 | 08:32 PM
Schister66's Avatar
Man U FTW
you dont need a BB turbo to spool fast...especially not for that low power goal. You could find plenty of cheaper journal bearing turbos that would spool in that same range and make that power.
My GT3255 should see full boost by 3-3200 rpm and on 11psi, make around 320whp....its journal bearing....you draw your own conclusions
Old Mar 7, 2007 | 09:14 PM
RJH6's Avatar
I have a full-race T3T67 turbo, and it spools up aroud 5,100 at 23psi....
Old Mar 8, 2007 | 05:06 AM
Default Re: t3/t4 spool up? (RJH6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJH6 &raquo;</TD></TR><TR><TD CLASS="quote">I have a full-race T3T67 turbo, and it spools up aroud 5,100 at 23psi....</TD></TR></TABLE>
uhhh ok good for you but that has no relevance to the topic.
Just pick up a t25/14b from an eclipse or a straight t3 from a volvo mate it to an HF manifold w/ adapter plate and you are on your way, just make sure you have some extra funds like previously stated because something will break, there is no question...
Kp_VtekNiks
Jul 30, 2003 12:26 PM
austrian type-R
Jun 4, 2003 09:47 AM
Andrew 825SM
Jun 20, 2002 12:04 AM
