ngk BKR6E-11 turbo gap?
Hi i searched but couldnt find exactly what i wanted to know so.. What should my sparkplug gap be on a b16a3 turbo? ngks NKR6E-11? thanks in advance.
I don't know why this bothers me, but WHY do you guys buy the "-11" plugs? Get the regular BKR7E. The only difference between BKR7E and BKR7E-11 is the larger gap the "-11" come with, which is 1.1mm (.04331"). The standard BKR7E have a smaller gap (I'm pretty sure it's .8mm (.0315")).
Edit...Oh, my BKR7E plugs are gapped to .030". Most people will give you a range of .028" - .032".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets »</TD></TR><TR><TD CLASS="quote">I don't know why this bothers me, but WHY do you guys buy the "-11" plugs? Get the regular BKR7E. The only difference between BKR7E and BKR7E-11 is the larger gap the "-11" come with, which is 1.1mm (.04331"). The standard BKR7E have a smaller gap (I'm pretty sure it's .8mm (.0315")).
Edit...Oh, my BKR7E plugs are gapped to .030". Most people will give you a range of .028" - .032".</TD></TR></TABLE>
For some unknown reason, the -11's are usually in stock at local stores down here as to the non -11 model is not :-p
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">For some unknown reason, the -11's are usually in stock at local stores down here as to the non -11 model is not :-p</TD></TR></TABLE>
That's a good reason!
