Speakers running off 4 channel.
Old Mar 5, 2007 | 03:24 PM
WalkerGSR1's Avatar
Default Speakers running off 4 channel.
Today i setup m speakers to run off 4 channel, when i went to play a cd the right side of the car only played and the left(drivers side) played extremely low. Any1 have any input on this?
Old Mar 5, 2007 | 05:51 PM
WalkerGSR1's Avatar
bump
Old Mar 5, 2007 | 06:05 PM
02 accord's Avatar
Default Re: (WalkerGSR1)
Switch the left and right rcas and see if the problem moves to the other side. If it stays, then it could be a bad gain pot on the amp. If it moves, the problem is with the headunit.
Old Mar 5, 2007 | 06:06 PM
fcm's Avatar
fcm
Old Fart
Check for a short it the wiring for the speaker wiring, start by just switching the left and right RCAs, if problem is still there, switch the RCAs back and switch the speaker outputs on the amp, again left to right, if problem is still on the drivers side you have a short in the wiring to the front or rear speaker, disconnect and try one at a time, the short is in the one that does not work. 94
Old Mar 5, 2007 | 06:25 PM
WalkerGSR1's Avatar
Ight hopefully its a little warmer outside tommorow. I will try that and get back to you guys.
bmxkills
Audio / Security / Video
Oct 13, 2009 06:31 PM
musashiasano
Apr 19, 2009 12:10 PM
HONDRETTI
Sep 29, 2008 05:41 AM
Rob :190:
Jan 1, 2003 11:02 AM
CivicHB-Si
Jun 4, 2002 07:40 PM
