d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo
Old May 22, 2002 | 07:11 AM
89 CRX SI's Avatar
Default d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo
Any advantages to swapping entire d16z6 motor in or just swap heads since i already have 1.6 L
Is d16z6 block any stronger for N2O ??
THX
Old May 22, 2002 | 07:13 AM
markedOO1's Avatar
Default Re: d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo (89 CRX SI)
z6 head on a6 block yields a pretty high compression ratio...not ideal for boosting.. although it certainly can and has been done..
Old May 22, 2002 | 07:17 AM
89 CRX SI's Avatar
Default Re: d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo (marked001)
mmmmmm that sucks caouse i wanted to boost like 10 Psi through it.
I guess ill have to find the hole engine.
Can the complete d16z6 bolt in and is almost plug and play but VTEC ??
THX
Old May 22, 2002 | 07:18 AM
markedOO1's Avatar
it bolts in like stock pretty much b/c you use all the stock mounts...wiring difficultly really depends on the route you take...
Old May 22, 2002 | 07:20 AM
89 CRX SI's Avatar
is it OBD 1 ???? can I change entire harness for engine bay and interior harness and fuse box over. THX
I got a V-AFC off Ebay so i dont need no stinking RPM activated crap. I would be using Zydne also
Old May 22, 2002 | 07:26 AM
markedOO1's Avatar
...then you wont need to run it OBD1...just use the stock harness and run it OBD0 w/ the zdyne ecu and vafc....only a few plugs need some lengthening/modification...
Old May 22, 2002 | 08:28 AM
ImportHatch's Avatar
You could use the obd1 ecu and then wouldnt have to worry about activating vtec and with the p28 ecu you will have fuel mapping for the vtec. Either way you wanna go....
Yager-
Old May 22, 2002 | 08:50 AM
crx(gator)'s Avatar
high compression is good for n2o btw...but not to much with a stock bottom end...
Old May 22, 2002 | 12:04 PM
AbaZ's Avatar
THX
Why not just run 7-8 psi on a D16a6 with a Z6 head? it will be just as fast, if not faster then a D16z6 at 10psi. The higher C/R will make up for it. Mini-me's respond quite well to forced induction.. I ran 8.5psi on mine (d15b2/z6 head) and pulled a 13.5
Jeff
(proper fuel/spark management will be needed)
travisjmercer
Sep 22, 2013 04:12 AM
lilshady6796
Sep 5, 2009 08:13 AM
93eghb
Feb 17, 2008 11:44 AM
Singlefury
18
Feb 16, 2006 07:33 AM
