d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo
Any advantages to swapping entire d16z6 motor in or just swap heads since i already have 1.6 L
Is d16z6 block any stronger for N2O ??
THX
THX
Re: d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo (89 CRX SI)
z6 head on a6 block yields a pretty high compression ratio...not ideal for boosting.. although it certainly can and has been done..
Re: d16Z6 turbo...... D16Z6 longblock turbo or d16a6 w/ y8 head Turbo (marked001)
mmmmmm that sucks caouse i wanted to boost like 10 Psi through it.
I guess ill have to find the hole engine.
Can the complete d16z6 bolt in and is almost plug and play but VTEC ??
THX
THX
it bolts in like stock pretty much b/c you use all the stock mounts...wiring difficultly really depends on the route you take...
is it OBD 1 ???? can I change entire harness for engine bay and interior harness and fuse box over. THX
I got a V-AFC off Ebay so i dont need no stinking RPM activated crap. I would be using Zydne also
...then you wont need to run it OBD1...just use the stock harness and run it OBD0 w/ the zdyne ecu and vafc....only a few plugs need some lengthening/modification...
You could use the obd1 ecu and then wouldnt have to worry about activating vtec and with the p28 ecu you will have fuel mapping for the vtec. Either way you wanna go....
Yager-
Yager-
high compression is good for n2o btw...but not to much with a stock bottom end...
THX
THX
Jeff
(proper fuel/spark management will be needed)
93eghb
02-17-2008 11:44 AM
