What sensor/switch is this?
Old Mar 5, 2007 | 07:36 AM
ctownintegra's Avatar
Default What sensor/switch is this?
I'm guessing oil pressure, but mine is leaking very very badly. Also, from looking, this is an oil pressure switch, but not the one for vtec? That one is mounted on the solenoid itselft correct? At work (O'Reilly), I looked up one and there are two that look identical but have two diffent part numbers.
Old Mar 5, 2007 | 08:43 AM
PA MATT's Avatar
Default Re: What sensor/switch is this? (ctownintegra)
free bump...I'll try looking around for ya
Modified by PA MATT at 12:59 PM 3/5/2007
Old Mar 5, 2007 | 08:50 AM
Nah, there's one right beside it that is the coolant temp for the gauge. This one is leaking oil through the plug, running down th eblock puring over the front and causing a mess.
Old Mar 5, 2007 | 03:12 PM
Mikey3000's Avatar
Default Re: (ctownintegra)
hm thats a good question. is there a connector on your thermostat? if not, thats the water temp. sending unit. otherwise i have no clue. what motor is that? have you looked at hondaautomotiveparts.com?
Old Mar 5, 2007 | 05:02 PM
PyroProblem's Avatar
Im almost positive it is a coolant temp sensor.
And the single wire sensor beside it is for the guage.
Usually the distributor O ring is the culprit of oil leaks in that area.
M-benz
Oct 8, 2013 04:56 AM
91akira
Jul 1, 2009 07:51 PM
ttmitsu
Oct 12, 2005 10:44 AM
Jdmglenn
Dec 20, 2004 01:05 PM
zCivic
Jul 29, 2003 08:36 AM
