what sensor is this?
Old Dec 19, 2004 | 05:12 PM
Jdmglenn's Avatar
Default what sensor is this?
i have a 95 gsr head and its next to the water temp sensor?? its black and has two pins in it , also there is a sensor on the thermo housing , is that the fan switch???
thanks honda-tech
Old Dec 19, 2004 | 05:40 PM
86si's Avatar
Default Re: what sensor is this? (JdmGlenn)
ECT or TW (coolant temp sensor) it is for the ecu's reference
Old Dec 19, 2004 | 06:18 PM
Jdmglenn's Avatar
so the one by the vtec oil pressure switch is for the ecu's reference? whats the one on the thermostat housing?
Old Dec 20, 2004 | 11:18 AM
Jdmglenn's Avatar
bump
Old Dec 20, 2004 | 11:41 AM
tgreaves's Avatar
Default Re: (JdmGlenn)
The one on the thermo housing is the thermo switch.. Its just a temp controlled relay, when the circuit is completed the fans turn on..
Old Dec 20, 2004 | 12:58 PM
Jdmglenn's Avatar
oh ok so the one on thermo is fan switch and the lil 2pin sensor by the oil pressure switch is the coolant temp for ecu not the cluster?
Old Dec 20, 2004 | 01:05 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn &raquo;</TD></TR><TR><TD CLASS="quote">oh ok so the one on thermo is fan switch and the lil 2pin sensor by the oil pressure switch is the coolant temp for ecu not the cluster?</TD></TR></TABLE>
???? The obd0 motor had the thermo switch on the back of the motor and obd1+ has it on the thermostat housing.. Are you using a obd1 thermostat housing on an obd0 motor?
motegicivic
19
Oct 12, 2017 10:28 AM
nogodracer23
Nov 20, 2013 12:10 PM
91akira
Jul 1, 2009 07:51 PM
irishflame27
Jan 6, 2009 01:55 PM
