Installing Coolant Temp Warning Light System
Old Mar 4, 2007 | 10:33 PM
Nisif's Avatar
Default Installing Coolant Temp Warning Light System
I'd like to install a warning light that automatically turns on if my car ever begins to overheat. Any ideas where I should mount a temperature switch? Also, at what temperature does the car start to overheat or get "too hot"? I'm assuming around 220 degrees or so, just wanted some input. TIA
Old Mar 4, 2007 | 10:37 PM
Nisif's Avatar
Default Re: Installing Coolant Temp Warning Light System (Nisif)
Found this on Autometer's website, looks like a start:
http://autometer.com/cat_acces...d=182
Any suggestions where I should "tee" the switch into?
Old Mar 5, 2007 | 12:14 PM
Perfectionist's Avatar
The radiator fan on most models runs when the temp switch closes and completes the fan circuit ground when the engine gets hot enough. You could just tap the ground side of your warning light into the switch leg of the fan circuit.
Old Mar 5, 2007 | 03:48 PM
NJIN BUILDR's Avatar
Default Re: Installing Coolant Temp Warning Light System (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">The radiator fan on most models runs when the temp switch closes and completes the fan circuit ground when the engine gets hot enough. You could just tap the ground side of your warning light into the switch leg of the fan circuit.</TD></TR></TABLE>
Like he said.
maglites94
Mar 10, 2012 07:40 PM
hotcivicsi
19
May 15, 2009 01:54 PM
ATS*Mark
Dec 9, 2003 11:08 PM
HybridKOOP
Aug 14, 2002 11:08 AM
JDM_Type-R
Jun 16, 2002 08:31 PM
