car wont move HELP!
well i dropped a b16a 1st gen in my std hatchback with s1 tranny.my car has been driven for about 3 months now.one day while at mcdz drive through my car gets stuck. it goes in all goes but it doesnt move.reverse works.i could reverse just alittle bit then stops me and rolls me back into my spot where i was stuck at.
wen i put it in gear it stalls out wen i try to let off in first gear and balance the clutch n gas out the rpms drop as i let the clutch out.i tried this in all gears and it still doesnt move.the car idles fine and revs fine.
any ideas?
any ideas?
hmmmm..... if you have access to a lift, I'd lift the car and try it with the wheels in the air to see what happens.
DO NOT try that using a jack or somethin like that, if it falls and the car goes you'll be sorry.
yes i could get it in all gears.no my ebrake is not loose. but yah he has started leakin tranny fluid. but it doesnt seem like its comin from a crack i was thinkin it was comin from one of the axles because wen i got my swap one of the axles were messed up and i didnt get a new one. my mechanic just fixed the axle but i was wondering can that axle get all messed up again while its in the tranny? wut if i jack it up and put jack stands would that be fine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlusiveracer »</TD></TR><TR><TD CLASS="quote"> wut if i jack it up and put jack stands would that be fine?</TD></TR></TABLE>
Thats still dangerous.... if your comfortable with it, go for it, but be CAUTIOUS.
I'd just be tryin to see if the axles can move freely if the cars in the air, and if either of the CV joints are broke. It's my guess either your axles are the cause, or your tranny is messed up.
Thats the only reason I can think that it'd work a little in reverse but not at all in gear is if your tranny is messed up (I dont know much about the mechanics of trannys)
alrite thanks.yah because i dont knoe how im goin to beable to get to a lift cause my car cant move unless i call n tow truck n pay them to tow it to a shop.
CiViC_SOHC
16
Mar 17, 2007 10:06 AM
