No Spark.......HELP PLEASE
Old Mar 3, 2007 | 07:43 AM
irishgod247's Avatar
Default No Spark.......HELP PLEASE
I have a 98 Honda Civic EX 2 dr 5 speed. I am getting no spark, have replaced spark plugs and wires, tried to take off distributor cap to get to ignition module to test it and broke off my rotor under the distributor cap trying to take the rotor off. First how do u get the rotor off....just pull or is there a screw I am missing? Also I have the ignition module out except for the wires that are screwed in and the screws are rusted....any suggestions how to get em loose without WD 40? Any suggestions on any of this at all would help out. Thanks.
Old Mar 3, 2007 | 07:52 AM
turbociviccoupe's Avatar
Default Re: No Spark.......HELP PLEASE (irishgod247)
to take the rotor off you need to take the screw off located on the shaft first...you cant miss it. for the bolts to the igniter what i do is get a screwdriver bit hammer it on there and make sure it locks on tight. then use a socket and rachet to get it off...make sure its a small pointy bit though...hope that helps bro.
Old Mar 3, 2007 | 07:55 AM
JDM_Frijoles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irishgod247 &raquo;</TD></TR><TR><TD CLASS="quote"> I am getting no spark, have replaced spark plugs and wires, tried to take off distributor cap to get to ignition module to test it and broke off my rotor under the distributor cap trying to take the rotor off. First how do u get the rotor off....just pull or is there a screw I am missing?
</TD></TR></TABLE> More than likely the screw is in a position where you cant see it...........happened to me put the car in gear and push/rock it forward until you get access to it
Old Mar 3, 2007 | 01:33 PM
I found the screw and was pretty easy to take the rotor off after that. thanks for the help guys.
philpsu
Jul 17, 2007 05:08 PM
zerogravitycrx
87
Dec 15, 2006 12:03 PM
rice a roni
Mar 23, 2006 12:37 PM
sodacan33
Jun 17, 2004 06:53 PM
