worth it? need opinions quick
Old Mar 2, 2007 | 12:15 PM
MattsGreenEG's Avatar
Default worth it? need opinions quick
well i found a eg with a b16 in it for 2000. thing is car turns on but doesnt run. he said it needs a throttle cable and other things but he doesnt know for sure. should i risk it and buy it cuz i am in real need of a eg since i just crashed mines. im not sure if i should risk cuz i dont know much about motor work.
Old Mar 2, 2007 | 12:18 PM
Projekt_2nr's Avatar
Default Re: worth it? need opinions quick (MattsGreenEG)
i'd buy it, could be something very simple, i once bought a 93 coupe for 1500 with a gsr, turned out the fuel pump was bad haha
Old Mar 2, 2007 | 12:20 PM
kuja396's Avatar
Hard to say imo. A throttle cable isn't going to make the car not idle thats for sure. Or is that whet you mean when you said turns on? If it does idle, let it idle and listen for anything strange... then check the oil... then ask/do a leakdown test on it. If you can do all of that (assumeing it idles) then you should be good to go.. Oh and work the throttle body with your hand to rev it up and listen for a spun rod bearing.
I looked at your other thread, sucks man
Old Mar 2, 2007 | 12:22 PM
singlecamEJ8's Avatar
Default Re: worth it? need opinions quick (Projekt_2nr)
i would go for it.
just getting ti in your name might be difficult if it doesnt run....unless you got a hookup
Old Mar 2, 2007 | 02:37 PM
blinx9900's Avatar
if the body is strait jump on it, also turn it on, rev the **** out of it, if it sounds good, buy it, worse case scenario is the tranny is bad.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
cdmef
Jul 3, 2011 06:03 AM
gsrEGcoupe
Nov 15, 2008 12:51 PM
Flite
Jun 3, 2008 12:30 PM
tomy_r
Jan 12, 2006 06:34 AM
