Type One muffler rattling
Old May 21, 2002 | 05:17 PM
nwdave's Avatar
Default Type One muffler rattling
Posting this here because I figured a few more guys with ITRs had Type One mufflers than the people over in the EG forum.
Anyway, I installed my Type One EG6 rear section on Sunday. I love the sound, but today the muffler is rattling out of control. To me, it sounds like something came loose inside the muffler and is rattling around. Anyone have any idea what it could be or if there is anything I could do to fix it?
Old May 21, 2002 | 05:20 PM
ALLMOTOR18's Avatar
Default Re: Type One muffler rattling (delsolguy)
do you have a straight pipe?. if so, thats what you get when you use one.. you can try to put a resonator in your b-pipe to make it deeper sounding..
Old May 21, 2002 | 05:43 PM
B2FiNiTY's Avatar
Mine doesn't do that at all. Try removing the axle back and tell us what happens.
Old May 21, 2002 | 06:02 PM
nwdave's Avatar
Default Re: Type One muffler rattling (B2FiNiTY)
I have a cat, but no resonator. Does that count as a straight pipe? And it's not the loudness I'm concerned about, it's the rattling.
B2FiNiTY: So you want me to just take off the muffler and see if the exhaust still rattles? I don't know...to me it really sounds as if the noise is coming from the muffler itself.
B2FiNiTY's Avatar
No, I mean, take off your axle back and then use your hands and shake it and see if you hear anything wrong with the muffler.
Old May 21, 2002 | 06:10 PM
nwdave's Avatar
Oh I see. Duh.
Ok I'll give that a try tomorrow.
Old May 21, 2002 | 06:22 PM
norice's Avatar
You may be hitting one of the heat shields somewhere. Look for areas of very little clearance between the exhaust and the heat shields. You may be able to stretch the hangers to get more clearance.
Old May 21, 2002 | 06:56 PM
Reid's Avatar
Global Moderator
Default Re: Type One muffler rattling (Todatyper028)
The rattling you describe sounds like a heatshield. Check the one under the shift linkage first.
Either that or you have one with defective bearings.
Old May 21, 2002 | 07:08 PM
Bob#455's Avatar
Default Re: Type One muffler rattling (Reid)
LOL, if this is the case you'd better call Type One, I could have sworn the bearings had a lifetime warranty.
Old May 21, 2002 | 07:12 PM
Wildohiorice's Avatar
New User
Default Re: Type One muffler rattling (Bob#455)
check your strap that holds the muffler in the back make sure its tight.
Old May 21, 2002 | 08:32 PM
nwdave's Avatar
Default Re: Type One muffler rattling (Wildohiorice)
Thanks for all the suggestions guys, I'll try 'em all out tomorrow.
Old May 21, 2002 | 10:34 PM
AJ PwR's Avatar
Try to replace the bolts which attach the B-pipe to the muffler or try not to use the springs.
Old May 21, 2002 | 10:47 PM
jonnybravo's Avatar
I bet it's your exhaust rattling against your suspesion arms. Or do you have a rear sway bar? It might be hitting that also. Try going out of your car and bang on the muffler up down and side to side. Min was hitting but I insulated my bars with rubber hose. Hope this helps.
Old May 22, 2002 | 04:09 AM
nwdave's Avatar
Default Re: Type One muffler rattling (jonnybravo)
That was my first thought. My car is fairly low, and there isn't a lot of clearance for the muffler (or rather, the pipe that goes over the LCA). So I started the car and went back to move some things around and see if the muffler was in fact hitting something. It's not. The thing barely moves, and it definitely does not move enough to hit any of the suspension.
Tom Jara
Jun 3, 2017 02:50 AM
Fnix
Dec 25, 2011 09:02 PM
lickety_britches
Nov 8, 2007 10:21 AM
RacerXintegra2k
Dec 28, 2002 09:35 AM
