speedometer risig with engine RPM
Old Feb 28, 2007 | 05:08 PM
ham's Avatar
ham
Default speedometer rising with engine RPM
93CX with a B18C1 has a problem with the speedo rising with RPM. Its really bad - at idle it reads about 10mph and as I rev it up to about 3 is reads about 40mph. There are no mechanical problems, its electronic. Engine runs fine and car drives fine. It didnt have the problem with the stock D series, only after the swap.
I tried different clusters and messed with all the wiring and I cannot seem to find anything wrong. The original non tach cluster does the same thing. I tried separating the wires in the harness to minimize interference. Has anybody else had this problem? Please post some possible causes! thanks!
EDIT 3-2: I messed with wiring / fuses and grounds and somehow fixed it. I had a TPS issue I also fixed, i heard its possible that it was related somehow.
Modified by ham at 9:19 AM 3/2/2007
Old Feb 28, 2007 | 05:09 PM
Dwight Schrute's Avatar
Default Re: speedometer risig with engine RPM (ham)
what about the actual speedo sensor on the tranny?
Old Feb 28, 2007 | 05:13 PM
MR.johnson's Avatar
Default Re: speedometer risig with engine RPM (drewthomas14)
bad ground.
Old Feb 28, 2007 | 05:14 PM
ham's Avatar
ham
whats goin on drew?
i tried unplugging the vss and it did nothing. its the RPM signal somehow getting into the vss signal, i dont know how or where though.
Old Feb 28, 2007 | 05:25 PM
skunk2eg's Avatar
a bad ground somewhere
Old Feb 28, 2007 | 05:49 PM
ham's Avatar
ham
Default Re: speedometer risig with engine RPM (skunk2eg)
where could there be a bad ground?
Old Feb 28, 2007 | 06:36 PM
20yrsToMidnight's Avatar
Or a bad fuse
Old Mar 1, 2007 | 04:51 PM
ham's Avatar
ham
Default Re: speedometer rising with engine RPM (ham)
i pulled all the fuses and checked them, and looked around at the wiring behind the cluster. i pulled the vss plug and made sure it has power and ground. i plugged everything back in and it went away! i fixed it but i dont know how.
Old Mar 1, 2007 | 06:18 PM
2wheelhunter's Avatar
fresh swap?... its an axle popped out, check 'em and make sure they're all the way in... also make sure it is in neutral when u rev.
Old Mar 1, 2007 | 06:36 PM
ham's Avatar
ham
Default Re: speedometer rising with engine RPM (2wheelhunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">fresh swap?... its an axle popped out, check 'em and make sure they're all the way in... also make sure it is in neutral when u rev.</TD></TR></TABLE>
woahhhh wayyy off dude
+ i fixed it
Old Mar 1, 2007 | 06:38 PM
Supra_y0's Avatar
when i read the title my first thought was bad clutch stuff but i'm not sure
maybe yeah a bad ground or something.
does the car move okay or what.
Old Mar 1, 2007 | 06:40 PM
blackrag's Avatar
Default Re: (Supra_y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supra_y0 &raquo;</TD></TR><TR><TD CLASS="quote">when i read the title my first thought was bad clutch stuff but i'm not sure
does the car move okay or what.</TD></TR></TABLE>
HE. FIXED. IT.
honest, do you read the threads?
Old Mar 1, 2007 | 06:49 PM
Default Re: (blackrag)
i just suggested that becuase that was what happened to me exactly as you explained it.. sorry boss
Old Mar 1, 2007 | 06:54 PM
Default Re: (2wheelhunter)
hmmm i still think you should check your axles... because if it is in nuetral then it will fix the problem but as soon as it goes back into gear it will happen again.. plus the car wont go anywhere.. lol do it for me so i can rest-assured
perhaps i'm wrong i give u permission to flame my ***
Old Mar 2, 2007 | 05:16 AM
ham's Avatar
ham
there was NO mechanical problems with anything, only the interference in the wiring between the tach and speedo! im assuming it was the vss ground. the car ran and drove fine.
nychonda
Aug 22, 2012 10:38 AM
marks_lude
Apr 18, 2007 08:17 PM
esoterEK..
Sep 30, 2006 02:48 PM
ShagPower
Jun 14, 2006 01:28 PM
JDMKid71
Jun 27, 2005 09:55 PM
