Vitara pistons with Eagle rods for D16Y8. Does the block need notching?
Old Feb 28, 2007 | 04:58 PM
LudaChris's Avatar
Default Vitara pistons with Eagle rods for D16Y8. Does the block need notching?
Found some that did it anyways but I read one that said no need to notch if using Eagle Rods. Any inputs from anyone with this set up?
Old Feb 28, 2007 | 05:13 PM
MR.johnson's Avatar
Default Re: Vitara pistons with Eagle rods for D16Y8. Does the block need notching? (LudaChris)
you need to notch the block for them to clear.
Old Feb 28, 2007 | 05:44 PM
maynards_ek's Avatar
Default Re: Vitara pistons with Eagle rods for D16Y8. Does the block need notching? (MR.johnson)
Why dont you put your entire rotating assembly(pistons,rods,crank) in without notching the block first, leave the oil pan off, and turn the crank while watching your rods move. After doing this, then you tell us if you need to notch it first.
Old Feb 28, 2007 | 05:46 PM
pdiggitydogg's Avatar
because you DO have to notch D blocks when using eagle rods
http://www.theoldone.com/artic...Ftips/
Old Feb 28, 2007 | 05:48 PM
tc07's Avatar
bump for single slam build
Old Feb 28, 2007 | 06:07 PM
Turbo_y8's Avatar
Default Re: Vitara pistons with Eagle rods for D16Y8. Does the block need notching? (tc07)
yes. i think you have to notch them on any now oe rod. i may be wrong but ls rods need to be notched.
Old Feb 28, 2007 | 06:38 PM
LudaChris's Avatar
Default Re: Vitara pistons with Eagle rods for D16Y8. Does the block need notching? (maynards_ek)
Thanks for the inputs.
vtechjunkie
Dec 7, 2008 01:00 PM
LudaChris
Feb 28, 2007 06:52 PM
brusk13
Jun 8, 2005 08:36 PM
DC2R714
Apr 28, 2003 09:19 AM
jazz215
Apr 17, 2003 08:22 PM
