HELP- New Cam/Gear Install, Problem with Idle.
i just got some ctr cams and aem gears put in and i noticed when i'm at a stop, my idle drops very low under 500 sometimes. It gets so bad sometimes my engine will just cut off but other times it's barely idling. Does anyone know how to adjust the idle or what the problem might be. Someone told me it was a screw on the throttle body. If so can someone tell me where this screw is.
check timing, might be off a tooth or so. And also check spark plug order. Could be a bad ground too...
For the screw is right on the top of the throttle body but before you adjust it make sure you take off the IACV. Other wise is wont work right. Then after that youll have to reset to ecu to get rid of the code you will throw when you do this.
01 itr dc2
Feb 28, 2007 02:02 PM
