Idle Problems Help
Old Jul 4, 2004 | 10:23 PM
HiChanDC2R's Avatar
Default Idle Problems Help
Hi guys, its been a long time.
A few days ago i had this problem. I started the engine and idling was at about 500rpm, so i accelerated the engine and then it wanted to turn off. So i left the car home. Now, not always, but sometimes idle is not regular. Goes from 800rpm to 500rpm. What can it be? A friend told me to clean the throttle body and maybe the manifold, what can i do, is there anything else i need to check?
Thanx!
Old Aug 23, 2007 | 05:00 PM
N1civicSi's Avatar
Default Re: Idle Problems Help (HiChanDC2R)
having the same problem can ne one help
Old Aug 23, 2007 | 05:11 PM
Cheeze's Avatar
Default Re: Idle Problems Help (N1civicSi)
You may want to try to clean out your iacv (idle air control valve). That's normally the case for the symptom you described. Here's how to clean if you don't know how.
http://www.team-integra.net/se...=1174
Old Aug 23, 2007 | 05:19 PM
JjuuN R's Avatar
Could even be something as simple as a spark plug going bad... check the easier stuff first.
Old Aug 23, 2007 | 05:21 PM
GO-FIGHT-KILL's Avatar
Like Cory said, check the easier stuff first. If that's not it, check your IACV, if that's not it, check your TPS. I have similar problems, with a bad TPS.
jboogiebrown
Feb 18, 2006 02:35 AM
ls-t del sol
Sep 27, 2004 11:49 AM
drisken
Sep 9, 2004 09:41 PM
4gen
Jan 11, 2004 05:28 PM
