New piston rings, what do I do?
Old May 21, 2002 | 03:50 PM
ITR1071's Avatar
Default New piston rings, what do I do?
I am going to put new rings on my pistons and I want to do it correctly. Can anyone tell me exactly all I should do. I heard I need to hone the block, get new bearings and stuff, but what exactly and what all can I do myself without taking it to a shop?
Old May 21, 2002 | 05:56 PM
PWRVTEC's Avatar
Default Re: New piston rings, what do I do? (undercoverSI)
How many miles are on it? What engine?
Well you need to check the bores of the cylinders for out of round, and if they are worn or out of round they need boring. After that, you need to hone the cylinders so that rings have a surface to seat to. It can be done by hand drill or bore and hone press which I am sure you dont have it your garage.
The last step is setting ring end gap.
Now keep in mind that this is a basic run down of what needs to be done. So I say if you have never done it or dont have the tool take it t a machine shop. It will only cost like 200 for them to do it.
[Modified by PWRVTEC, 9:57 PM 5/21/2002]
Old May 21, 2002 | 06:36 PM
ITR1071's Avatar
Default Re: New piston rings, what do I do? (PWRVTEC)
It is a 1990 JDM B16A1. It had, so I was told, 30k. I put new pistons in before I put it in the car so they have about 5k on them. I was going to hone it by drill in my garage. I thought I needed bearings and stuff. Is that all there is to it?
Old May 21, 2002 | 06:42 PM
PWRVTEC's Avatar
So you replaced the pistons but used the old rings? What type of pistons?
Also what type of rings do you plan on using?
If you are planning of pulling the engine anyway to do the rings, yes replace the bearings and seals.
I am really confussed on what you are trying to do and why you are doing it. Are you building the engine up? Are you burning oil and need new rings? What is the plan?
Old May 21, 2002 | 06:51 PM
tinkerbell's Avatar
a bit OT, but check this out regarding break-in of new rings...
http://www.mototuneusa.com/break_in_secrets.htm
what do you think?
t..
Old May 22, 2002 | 08:40 AM
ITR1071's Avatar
I first put in used 2000 SI pistons with new JE rings. I am going to put new SRP 8.5:1 pistons in with Eagle forged rods next. I wasn't burning oil, but I am building it up. I really took it out to replace the pistons because there was oil on top of them. I had used some non-Honda headgasket before and I think it was thinner. If I don't have to replace the rings I won't, because I really don't want to. I was going to do a wet compression test to see if the rings were bad. But by my symptonms I think it is a blown head gasket and bad timming. How do you tell if a head gasket is blown? How do you adjust timing? Where do I get bearings and seals and how do I know which ones I need?
PINKFIFFTY
Jan 25, 2015 07:01 PM
MAFDARK
Jul 25, 2006 03:10 PM
Drag-On
Apr 6, 2004 11:52 AM
xteg95
May 3, 2003 04:16 PM
xteg95
May 3, 2003 10:56 AM
