Low idle
i have a auto 91 teggy now when i drive the car and come to a full stop the idle drops very low when i throw it in N idle is fine... i already played wit the screw on the throttle body. also when i start the car it feels kinda of choppie lol til i give it some gas and its smooth again. i charged the battery and nuttin. can it be the alternator? please help me ....wat should i check!
Modified by 93BubbleCX at 1:58 AM 2/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93BubbleCX »</TD></TR><TR><TD CLASS="quote">wait dunno would that cause for my lights to dim down? and go wit the radio too? lol</TD></TR></TABLE>
you might want to check your battery and alternator do a voltage test and see how it is. If your lights dim a lot and your radio cuts out, you're not getting enough juice to power it up either your battery isnt keeping the charge and needs to be replaced or your alternator is shot. Most places do a free voltage test so go have a looksee and you should be fine.
just like da_33 said earlier, when I step on the brakes my rpm drops about 100 and dash lights dim. if thats whats happening its normal but if yours is dropping rpm by a lot first do the above instructions then check your grounds or vice versa
thanks sure thing i will go to autozone and get my batttery checkd also yesterday i was on the parkway and i hit the brakes radio cut off so i pulled over turn the car off n back on and the problem when away some crazy **** lol but i will check the battery
jdmstockeg6
Dec 1, 2008 08:24 AM
