IAC????
Old Oct 6, 2005 | 05:54 AM
planetstereo's Avatar
Default IAC????
I am getting a little idle fluctiation when i come to a complete stop.Sometimes it almost dies to where the battery light comes on.The battery and alternator have been checked and there fine.What i want to know is can i bypass the iac valve by cutting a peice of metal the same shape as the mating surface to the intake????and if i need to joining the two hoses together? It does to cold here in south carolina sometimes we see twenty degrees but not usually any lower.Ive heard it may rough idle first cranking it in the morning but after its warm its fine.if that is all the problems ill have i can deal with that. thanks for your help...
Old Oct 6, 2005 | 01:17 PM
m R g S r's Avatar
Default Re: IAC???? (planetstereo)
your car will throw a code and idle really low if you do that.
no bueno
Old Oct 6, 2005 | 02:25 PM
rainforest's Avatar
Default Re: IAC???? (m R g S r)
check your idle adjustment before you deem the iacv the problem. but for real its usually the iacv.
Old Oct 6, 2005 | 03:30 PM
Default Re: IAC???? (rainforest)
will incorrect idle adjustment on the throttle body screw make it run like that??/
Kindled Light
32
Mar 1, 2019 06:06 PM
jdm_prelude19
Apr 4, 2011 05:58 PM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
JSR
May 17, 2006 10:27 PM
Norcalstoppy
Oct 7, 2002 10:47 AM
