gsr hatch questions
i have a full gsr swap sittin in my garage and i wanna throw it into an EG hatch. what would the swap consist of? where can i get a wire harness for this swap and would my gsr ecu plug right in or do i have mickey mouse it? also, any tips on how to make the swap easier?
the swap should go in pretty easilly as long as you have
gsr motor and tranny
m & t mounts
half shafts
hubs
ecu
harness (ebay/salvage yard)
http://cgi.ebay.com/ebaymotors...ZWDVW
shift linkage
im probly forgetting something but i just helped put an ls in a 93 hatch and it wasn't really that hard had to drill some holes above the lower engine and tranny mount to spray anti seize on them to get the old engine out but other than that it went like butter
im also in maine were we don't have emissions so i can skip a couple eco friendly steps
m & t mounts
half shafts
hubs
ecu
shift linkage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton »</TD></TR><TR><TD CLASS="quote">what do i need gsr hubs for? isnt there a company that selld engine harnesses specifically made for these kinda swaps?</TD></TR></TABLE>
same hub...there used to be a guy that sells made wiring hharness on here but it would be cheaper to wire yourself...its not hard just try it
if you want to modify your harness check http://stores.ebay.com/HONDAPARTSHERO
that is the store i got my vtec harness threw
i have never done the gsr swap so i am not sure how much is different between it and an ls swap but this is what i know about it
boostshmoost
16
Jun 15, 2009 12:34 PM
Wrath of VTEC
Feb 3, 2002 03:53 PM
