IC piping question
Old Feb 26, 2007 | 05:59 PM
hondabigblock's Avatar
Default IC piping question
Has anyone had any luck keeping the oem fogs lamps on a 4thgen with a Front mount intercooler ? My piping seems like its going to be in the way no mater what I do. I really dont want to ditch my fogs
Old Feb 26, 2007 | 09:24 PM
esedulerp5tenin's Avatar
Default Re: IC piping question (hondabigblock)
had to ditch mine too cuz of the FMIC
i think mostly everyone else had to too.
ever think of SMIC?
Old Feb 26, 2007 | 10:44 PM
darkspector2.0's Avatar
top mount and hood scoop ftw!
Old Feb 27, 2007 | 03:55 AM
Default Re: (darkspector2.0)
I guess mine are coming out.
Old Feb 27, 2007 | 04:55 AM
clemsoncb7's Avatar
Default Re: (hondabigblock)
Mine were just fine.... I cut the center support that the hood latch is on out and I tucked my IC back further. If I even had fogs it would have fit fine.
Max
Old Feb 27, 2007 | 11:09 AM
Vilmar's Avatar
Sorry for the off topic, but can I use 5gen IC piping kit in my 4gen ? with litle mods
Old Feb 27, 2007 | 01:08 PM
Default Re: (Vilmar)
Thanks for the suggestions. Yeah it should fit you might have to make minor modifcations though
Old Feb 27, 2007 | 01:22 PM
RA102725's Avatar
Default Re: (boostfedbb)
hmm.. does cutting that support damage the rigidity of the front of the car? not sure if thats a vital component or a useless bar for the hood.. also what kind of radiator did you run behind it? stock?
what other altercations have people made to make a fmic fit at all?
Old Feb 27, 2007 | 01:48 PM
Ludster's Avatar
Default Re: (mikesta21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesta21 &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. does cutting that support damage the rigidity of the front of the car? not sure if thats a vital component or a useless bar for the hood.. also what kind of radiator did you run behind it? stock?
I'll take some pics of mine in a few minutes, but the bumper support is used for head on collisions.
I cut my bumper support to keep my jdm fogs on.
Old Feb 27, 2007 | 02:05 PM
Ludster's Avatar
Default Re: (Ludster)
My front bumper was also modifed, I had to remove some material from the bottom and the grill.
Old Feb 28, 2007 | 04:43 AM
Anyone want to buy some Yellow jdm fogs pm me
Old Feb 28, 2007 | 09:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vilmar &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the off topic, but can I use 5gen IC piping kit in my 4gen ? with litle mods</TD></TR></TABLE>
yes you can, i am using an entire 5th gen turbo kit on my 4th gen, and modifying as necessary. 3 out of the 4 pipes fit perfectly, and the last one i simply need to cut 2 90 degree bends off and weld a straight section on. this is due to the different wastegate placement from having a different manifold between H22 and 23's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabigblock &raquo;</TD></TR><TR><TD CLASS="quote">Anyone want to buy some Yellow jdm fogs pm me </TD></TR></TABLE>
hahahahaha, i'm doing exactly the same. can get some good $$$ for the yellows
this is how my 6" is mounted, didn't cut ANYTHING from the bumper support, and i CAN'T use my fogs. FYI.
Old Feb 28, 2007 | 10:42 PM
Ludster's Avatar
Default Re: (esedulerp5tenin)
^^^keep up the work, Is your hot and cold side piping the same size?
maybe i'll take some pics with the bumper on.
Old Mar 1, 2007 | 03:41 AM
Preludepradit's Avatar
My setup is the Same as Ludster and I'm not having any probs with the fogs needing to come out. I had to trim things a it to keep them but they are still there. I had to chop my entire hood mounting bracket all the way out though. I just didnt want to take out my RE-Bar and tilted it back a bit. If you want a pic let me know.
Old Mar 1, 2007 | 05:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludster &raquo;</TD></TR><TR><TD CLASS="quote">^^^keep up the work, Is your hot and cold side piping the same size?
very first hot pipe is 2", second hot pipe is 2.5", and both cold pipes are also 2.5"
iamthefollower
Jul 13, 2011 11:53 AM
bart2546
Mar 5, 2007 06:20 PM
theEGkid
Jul 19, 2005 08:58 AM
BlackB18CTeg
Jun 28, 2003 11:21 PM
VTEC-DA
Feb 5, 2003 09:35 AM
