Supercharger for DA
do anybody know if they make a Supercharger for the B18a1. I know they make one for the B18b1 but not sure bout the a1 it for my DA.
thanks in advance if anyone knows.
If you do a little research, you will find that it is not your engine that is the problem. The major problem is the brake booster & MC when it comes to units like the JRSC. You might have better luck adapting the Vortech unit. Then you have to ask yourself "Why would I do that when I could just use a turbo?"
You'll get the idea with a bit more research.
a supercharger like a jackson racing one for a dc will not fit..it will hit the fire wall
i would get an account on G2IC.com alot more things covering our cars..
then you"ll have both honda-tech and g2ic yay!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da_Enthusiast »</TD></TR><TR><TD CLASS="quote">a supercharger like a jackson racing one for a dc will not fit..it will hit the fire wall
then you"ll have both honda-tech and g2ic yay!!</TD></TR></TABLE>
Not true. As I stated before the JRSC in a Gen2 will hit the MC/booster. It can be done though.
I would second the g2ic.com account. There is an old thread on there documenting a member with a 92-93 GS-R with the JRSC + cooler installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kennyboi »</TD></TR><TR><TD CLASS="quote">my question is will the B18b1 non vtec supercharger fit my B18a1 I heard the only diffrence is the OBD's they are the same heads right (so it should fit)</TD></TR></TABLE>
Yes it will fit, it's been done before. Like others said, it has trouble fitting with the brake MC. I've seen pictures where people have done it though, a few looked as if they had either filed off some extra unimportant material or had rotated the whole unit.
sorry lol
http://www.g2ic.com/forums/sho...B18a1
~ it can be done...i was just negative that day on my last comment
yea, a good wire tuck..do something with the valve cover and some headers and it would look nice..
While this is a Vortech on a 92-93 DB, it may be of interest to some on this subject:
http://www.g2ic.com/forums/sho...age=2
