Problems with the clutch... is it time to replace?
Old Feb 26, 2007 | 03:16 AM
tommyofyork's Avatar
Default Problems with the clutch... is it time to replace?
Alright, I'm new to the world of civics - I just picked up a '98 EJ Civic about a month ago. I'm also pretty new to the world of cars, so if I sound pretty newb, I apologize.
Everything's stock, and I believe nothing major has been replaced in the last 72k miles.
So, as for the clutch...
The clutch definitely doesn't catch smoothly - lifting my foot off the clutch pedal, it catches almost instantly right as I lift the pedal even slightly. I guess this is just a symptom of a worn and tired clutch, but... shifting from second to third, it loves to make a delicious grinding sound. So, I'm in second, I push the clutch all the way in, I push the stick up into third, and crunch. Bad synchro, I guess.
So, I guess the question is... should I replace the clutch/flywheel?
Old Feb 26, 2007 | 04:37 AM
Luserkid's Avatar
Default Re: Problems with the clutch... is it time to replace? (tommyofyork)
Sounds like you need to practice driving more and bleed the clutch.
Old Feb 26, 2007 | 06:30 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Problems with the clutch... is it time to replace? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you need to practice driving more and bleed the clutch. </TD></TR></TABLE>
x2
Old Feb 26, 2007 | 06:52 AM
pkdog167's Avatar
Default Re: Problems with the clutch... is it time to replace? (ek forever guy)
X3
Old Feb 26, 2007 | 05:35 PM
ej63_civic's Avatar
.Ouch man. The ej clutch is pretty damn durable man. It sounds like a clutch to me. It could be allot of different things, clutch disk, throw out bearing, pressure plate. It could be allot of different things. Dot mess with it man, just get a new clutch kit and have a professional look at it. Clutches are tricky man, so if you don’t know what you’re doing just let some one else put it in.
P.S. get it done soon, because once that syncro is dead it’s gone forever, then you have to buy a new tranny. So save your self-the headache and get it done ASAP
Old Feb 27, 2007 | 05:18 PM
hypertensor25's Avatar
Default Re: (ej63_civic)
I have a 98 Civic with the D16Y8 engine, and I'm having similar issues with my clutch. I don't have any problems with the transmission as far as I can tell, but my clutch seems weak. It's always been very picky ever since I bought it, and I just assumed it was a characteristic of the Honda clutch. No matter how carefully I release the damn clutch pedal, it will engage very abruptly, as though I dropped the clutch right from the floor. It's difficult to get going from a stop in 1st gear (like I mean without my full concecntration it will buck and chug) and just a little too much gas between gears and I get that embarassing rev down as it evens out...now I've been driving this car for two years and I still can't seem to master the 5-speed. Do you guys think I have a bad clutch?
I just got an Exedy Stage 1 clutch kit on eBay...waiting to get my mechanic to put'er in. What do ya think?
Old Feb 27, 2007 | 05:57 PM
95jdmferio's Avatar
swap it
EKHWhat
Feb 25, 2007 08:08 PM
MachinaInfernus
Feb 24, 2007 07:34 PM
imadigitalgod
11
Nov 18, 2006 11:27 PM
turnsignalandy
14
Aug 22, 2006 07:13 AM
JoNNiE
May 23, 2005 06:42 PM
