biggest throttle body on a jg im...
Old Feb 25, 2007 | 12:36 PM
turboedc2's Avatar
Default biggest throttle body on a jg im...
i would like to know what is the biggest size throttle body you can run on a jg intake manifold im planning on running a bdl 74mm but i wanna know if am gonna run into problems boring it any help would be great thanks.
Old Feb 25, 2007 | 01:06 PM
D-tuned's Avatar
Default Re: biggest throttle body on a jg im... (turboedc2)
you should be good. i'm running a 75mm on my jg
Old Feb 25, 2007 | 01:17 PM
turboedc2's Avatar
Default Re: biggest throttle body on a jg im... (D-tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-tuned &raquo;</TD></TR><TR><TD CLASS="quote">you should be good. i'm running a 75mm on my jg</TD></TR></TABLE>
with no spacer you just bored it...
Old Feb 25, 2007 | 01:37 PM
D-tuned's Avatar
with spacer both bored to 75mm
Old Feb 25, 2007 | 06:35 PM
Turbocivic94's Avatar
I've ran 74mm on my JG
Old Feb 25, 2007 | 07:09 PM
Muckman's Avatar
Moderator in Chief
who makes a 75mm TB? Are you running 3" charge piping?
Old Feb 25, 2007 | 07:10 PM
zexxbo's Avatar
Default Re: biggest throttle body on a jg im... (Muckman)
full-race and wilson make 75mm throttle bodies, and also a mustang throttle body is 75mm as well.
Old Feb 25, 2007 | 08:00 PM
turboedc2's Avatar
Default Re: biggest throttle body on a jg im... (zeimbo)
thanks guys
Old Feb 26, 2007 | 01:23 AM
BoostFedDB8's Avatar
Sorry for the thread jacking but just wondering if the 75mm mustang throttle body will work with crome pro because of the different tps sensor and calibration. I really want to use that throttle body but heard that it can only be use on certain ems like aem.
Old Feb 26, 2007 | 02:25 AM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">who makes a 75mm TB? Are you running 3" charge piping?</TD></TR></TABLE>
its a mustang T/B. i'm running 3.5" charge pipe
Old Feb 26, 2007 | 03:13 AM
DaveF's Avatar
i used a 75mm holley mustang tb on my manifold with an adapter plate i had welded on. we then ported the mani out to 75 as well.
3inch charge piping
Old Feb 26, 2007 | 04:26 AM
93supercoupe's Avatar
Default Re: biggest throttle body on a jg im... (dturbocivic)
that is pure badass
I just scrapped a mustang TB and about 15 LS TB's, and still have more.
Old Apr 7, 2007 | 10:46 AM
ShawnR's Avatar
Default Re: biggest throttle body on a jg im... (93supercoupe)
i plan on running a 76 on my jg do u have to run a spacer? where would i get one from?
Old Apr 7, 2007 | 11:42 AM
80884's Avatar
Default Re: biggest throttle body on a jg im... (97gsrcoupe)
75mm 5.4L ford TB with no spacer. I forget but I think the TB was for an excursion or something.
Old Apr 7, 2007 | 11:45 AM
zexxbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i plan on running a 76 on my jg do u have to run a spacer? where would i get one from?</TD></TR></TABLE>
why would you need a 76?
Old Apr 7, 2007 | 11:46 AM
ShawnR's Avatar
76 or 77 is 3inch which is what size charge pipe i am running.
Old Apr 7, 2007 | 01:10 PM
T Dohc's Avatar
I am running an RPM services 74mm on a jg just bored out.
Old Apr 7, 2007 | 04:24 PM
ShawnR's Avatar
Default Re: (T Dohc)
where did u get the throttle body from i can find a web sit that sells them
Old Apr 8, 2007 | 04:44 PM
80884's Avatar
Default Re: (97gsrcoupe)
https://honda-tech.com/zerothread?id=1140381
Old Apr 8, 2007 | 06:42 PM
civicjdmb16a's Avatar
http://yhst-54575482903972.sto....html
LagunaSecaEG
Aug 6, 2006 06:14 PM
xtremecoupe
Dec 16, 2005 01:31 PM
cjames235
Welding / Fabrication
Feb 3, 2005 05:36 PM
