biggest throttle body on a jg im...
i would like to know what is the biggest size throttle body you can run on a jg intake manifold im planning on running a bdl 74mm but i wanna know if am gonna run into problems boring it any help would be great thanks. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: biggest throttle body on a jg im... (turboedc2)
you should be good. i'm running a 75mm on my jg
Re: biggest throttle body on a jg im... (D-tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-tuned »</TD></TR><TR><TD CLASS="quote">you should be good. i'm running a 75mm on my jg</TD></TR></TABLE>
with no spacer you just bored it... |
with spacer both bored to 75mm
I've ran 74mm on my JG
who makes a 75mm TB? Are you running 3" charge piping?
Re: biggest throttle body on a jg im... (Muckman)
full-race and wilson make 75mm throttle bodies, and also a mustang throttle body is 75mm as well.
Re: biggest throttle body on a jg im... (zeimbo)
Sorry for the thread jacking but just wondering if the 75mm mustang throttle body will work with crome pro because of the different tps sensor and calibration. I really want to use that throttle body but heard that it can only be use on certain ems like aem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">who makes a 75mm TB? Are you running 3" charge piping?</TD></TR></TABLE>
its a mustang T/B. i'm running 3.5" charge pipe |
i used a 75mm holley mustang tb on my manifold with an adapter plate i had welded on. we then ported the mani out to 75 as well.
http://www.imagestation.com/picture/...7/f8ac270d.jpg 3inch charge piping http://www.imagestation.com/picture/...8/f75a7066.jpg |
Re: biggest throttle body on a jg im... (dturbocivic)
that is pure badass https://honda-tech.com/forums/images/smilies/emthup.gif
I just scrapped a mustang TB and about 15 LS TB's, and still have more. https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: biggest throttle body on a jg im... (93supercoupe)
i plan on running a 76 on my jg do u have to run a spacer? where would i get one from?
Re: biggest throttle body on a jg im... (97gsrcoupe)
75mm 5.4L ford TB with no spacer. I forget but I think the TB was for an excursion or something. https://honda-tech.com/forums/images...s/emsmilep.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrcoupe »</TD></TR><TR><TD CLASS="quote">i plan on running a 76 on my jg do u have to run a spacer? where would i get one from?</TD></TR></TABLE>
why would you need a 76? |
76 or 77 is 3inch which is what size charge pipe i am running.
I am running an RPM services 74mm on a jg just bored out.
Re: (T Dohc)
where did u get the throttle body from i can find a web sit that sells them
Re: (97gsrcoupe)
Re: (97gsrcoupe)
