my tranny is gone ?
Old Feb 25, 2007 | 11:06 AM
py389itr's Avatar
Default my tranny is gone ?
somebody help my out here my 5th gear at high rpm makes a squeeking / whinding noise when shifter into gear, but at 60mph i have to let the rpms drop real low then shift but at 65mph even at low rpm it still makes this funny *** noise its not grinding but its a weird sound. . . when in 5th gear there are no further problems it doesnt but out of gear or anything like that. . . i called some local shops and they really couldnt tell me nothing, but any advise really would be great. . thanks alot fellas
Old Feb 25, 2007 | 11:07 AM
Haleiwa-Brando's Avatar
Default Re: my tranny is gone ? (py389itr)
Just going to throw this out...did you check the fluid level? What fluid are you using? How many miles on said fluid?
Old Feb 25, 2007 | 02:46 PM
Boosted_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Just going to throw this out...did you check the fluid level? What fluid are you using? How many miles on said fluid?</TD></TR></TABLE>
Also, if the level is fine. Drain the oil out of tranny and look for metal shavings. Put in GM or royal purple syncromesh oil
Might help the problem
Old Feb 26, 2007 | 03:48 PM
REDLINEtypeR's Avatar
Default Re: my tranny is gone ? (Boosted_JDM)
Hit me up w/ an IM if you need it fixed. The only way to diag a trans is to hear it myself but, you should def. get it fixed b4 you tear up more than already is. That syncromesh or any other additive is a bandaid and does not fix the problem. Get it fixed.
Old Feb 26, 2007 | 05:04 PM
py389itr's Avatar
Default Re: my tranny is gone ? (REDLINEtypeR)
thanks for the help guys i have been wanting to actually check the fluid but the way the weather has been these past few weeks it hasnt even left the garage, i have been wanting to get the tranny flushed the right way, one of my mechanic buddies told me there is a pump kinda thingy that completely cleans the tranny out so i have been wanting to try that out.. . . but as far as i know it aint the syncros cuz there is no grinding. . . but i really worried about it. . . by the way what is GM oil ? ? ? i know what royal purple is and i was planning on going with that or just keeping the honda fluid. . .thanks again guys
Old Feb 27, 2007 | 09:19 PM
py389itr's Avatar
bump . . .any body else got any suggestions on what to do
Old Feb 28, 2007 | 02:34 AM
Doostur's Avatar
I personally would bring it somewhere like honda/acura and pay the 30-40 bucks diagnostic fee. From there you decide how and when to fix it, but at least you'll have alot better idea of whats wrong instead of guessing and spending money on something that may not fix it.
Old Feb 28, 2007 | 03:29 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py389itr &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help guys i have been wanting to actually check the fluid but the way the weather has been these past few weeks it hasnt even left the garage, i have been wanting to get the tranny flushed the right way, one of my mechanic buddies told me there is a pump kinda thingy that completely cleans the tranny out so i have been wanting to try that out.. . . but as far as i know it aint the syncros cuz there is no grinding. . . but i really worried about it. . . by the way what is GM oil ? ? ? i know what royal purple is and i was planning on going with that or just keeping the honda fluid. . .thanks again guys </TD></TR></TABLE>
Your mechanic friend is wrong, man. You dont pump out a manual trans. You do that to an automatic trans. There's nothing really to pump. The fluid just stagnates until the gears rotate into it and throw it everywhere. There's no pump in the trans....so pumping it out of the trans would be useless. Anyway, you dont need to pump it out. Just pull the drain plug, and it will all rush out. Just like oil. The reason to pump an automatic trans is to get all the fluid from the torque converter as well as the pan. Just:
1.) jack up the car
2.) make sure you can take off the 17mm fill bolt FIRST
3.) take off the drain bolt using a 3/8'' ratchet. The ratchet clips right into the bolt no socket.
4.) Drain into a relatively clean bucket so you can inspect for metal shavings.
5.) Let it drain for a while. Go eat a burrito, or watch some TV or something.
6.) Refill with geniune honda fluid. Some people suggest GM (general motors) Syncromesh or Royal purple.
7.) The full capacity of the trans is about 2.5 quarts. If you let it drain for an hour or more, you'll need that. If not, you'll need 2 quarts.
8.) Put drain plug back in, get a funnel with a spout and pour in the fluid into the hole for the 17mm fill plug you took off earlier.
9.) When fluid starts to run out of the trans, you're full. make sure the car is level when you're doing this. Jack up the rear as well. Put the drain plug back in
10.) ENJOY!
The above steps should only be followed if you know that the fluid is old and crappy or missing and causing your problems. If it's something else mechanical, changing the oil is useless, or at most a bandaid, as mentioned above.
Old Feb 28, 2007 | 04:41 PM
py389itr's Avatar
Default Re: my tranny is gone ? (B serious)
guys you all have been alot of help, i feel like such a damn noob but i jusst wanna keep my type r in the best shape possible super cle in and out, i will definetly drain the trans fluid when it gets warmer following your steps you provided thanks bro, , and i am definetly gonna be watching out for any sort of metal shavings, but i really dont wanna wait any long while it gets worse and worse i think i might also just take it to HONDA and watch the guy drain it hopefully there is n dick head manager around saying i cant be in the mechanics area, but i ll definetly be on the look out for the metal shaving i am very fearful my 3rd and 5th sync's are out. . . thanks again guys
JDM_J
13
Jan 22, 2009 04:01 PM
20ls01
Aug 3, 2007 10:18 PM
globy123
Dec 25, 2006 09:24 AM
J.nguyen
May 18, 2006 09:48 PM
hmongdude
Jul 14, 2003 01:17 PM
