axle problem!!!!!this is aggrivating
Old Feb 24, 2007 | 04:57 PM
jcfreibert's Avatar
Default axle problem!!!!!this is aggrivating
ok here's the situation....
92 cx hatchback
b16a swap
94 del sol tranny/w opm autosport lsd
92 integra halfshaft
here's my problem....changed the axle seal last week now the pass. side axle won't stay
in the tranny...i 've gotten 3 new axles for a 94 integra and they all do the smae thing....i've opened up all the clips on every one....and still the same thing....when it goes in, the inner joint is right on the axle seal so i don't see how it can go in anymore
,but it's like the clip is seating enough for me not to be able to pull it out by hand but when it gets moving it works its way out again...before i changed the seal it worked perfect...but it almost seems like the axle is a little short...there's a little stress on the inner joint but it kinda looks normal.....i'm all out of ideas....i've searched on every forum i can find for answers to this problem if any of you guys have ideas throw them my way cuz this is rediculous.....i 've done quite a few of these and never had a problem like this
-thnx
Old Feb 25, 2007 | 09:55 AM
jcfreibert's Avatar
Default Re: axle problem!!!!!this is aggrivating (jcfreibert)
bump
Old Feb 25, 2007 | 10:08 AM
fmrprojects's Avatar
could be the lsd, the axle is not seating in the grooves right
Old Feb 25, 2007 | 03:16 PM
jcfreibert's Avatar
Default Re: axle problem!!!!!this is aggrivating (fmrprojects)
it lines up with the splines and looks like it's in i can pull on the inner joint and it feels like its in....but for some reason i think the clip isn't seating properly.......my other theory is maybe i have the wrong axle...but all the part #'s are the same fro 90-01 integra and 94 del sol vtec....so i'm lost on this one
RanCRX
Dec 28, 2009 03:03 PM
jcfreibert
Apr 3, 2007 01:43 PM
jcfreibert
Feb 28, 2007 09:22 AM
turbotime
May 28, 2006 10:08 AM
crx8psi
Jun 16, 2004 04:39 AM
