internal wastegate actuator rod question
i got a bone stock d15b7 that im gonna boost. im gonna use a td04 turbo with an internal wastegate set at 8.7 psi.. i dont want to boost that much, i want to boost 5-6 psi. so my question is: the actuator rod on the wastegate has threads and a nut, so im guessing its adjustable? so if i make the rod longer, and have the flapper partially open, will it let me boost less?
it still has alot to do with the spring, but:
longer = less boost
shorter = more boost
the shorter the rod, the less it can open, less exh getting out, more boost.
longer = less boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">it still has alot to do with the spring, but:
longer = less boost
the shorter the rod, the less it can open, less exh getting out, more boost.</TD></TR></TABLE>
i konow it has to do with the spring, but its an internal wastegate and its sealed, so the spring cant be changed. so i will boost less if i make the rod longer right?
longer = less boost
you cant lower boost lower than what the wastegate is set for, so your only option is to get another actuator with a lower wastegate setting. but if i was you id just tune your car for 8 psi. It will handle it and be alot funner than 5 or 6 psi
B16Civic93
Apr 24, 2005 09:15 AM
