Bore limit on LS block?
Old Feb 26, 2007 | 08:59 AM
efKART's Avatar
Default Bore limit on LS block?
I have an LS motor in the machine shop and I was wondering what the limits on boring an LS block, its a limit and the machinist wants to bore it out pretty big(.050)since there are something wrong with the cylinder walls.
How much power can I make before I crack a sleeve with a bore like that, I plan on going FI in the future.
Old Feb 26, 2007 | 10:07 AM
SynTeg's Avatar
For boost I wouldn't go more than 81.5mm
Old Feb 26, 2007 | 10:45 AM
Muckman's Avatar
Moderator in Chief
Default Re: Bore limit on LS block? (efKART)
I agree, with stock sleeves no more than a standard .5 overbore. If you get it sleeved then 85 is the max.
Old Feb 26, 2007 | 10:48 AM
xsi-t's Avatar
Like everyone else said. 81.50 is the limit with boost IMO. You will see how thin the sleeves get at 81.50
Old Feb 26, 2007 | 11:21 AM
stockb18c's Avatar
^ yup
Old Feb 26, 2007 | 11:52 AM
boosted92's Avatar
Default Re: (stockb18c)
If he's actually talking about going .050" over, slap him. That's a 1.25mm overbore, and I don't know if the cylinders would stay round with an all motor application.
Old Feb 26, 2007 | 12:07 PM
nonvtecallmotor's Avatar
Default Re: (boosted92)
You can make 600+whp on a 81.5mm bore as long as your tune is good.
Old Feb 26, 2007 | 12:44 PM
taggart_lumpy's Avatar
not giving you any ideas but we had a 84mm stock sleeve ls that was boosted for a bit just had block filler in about the first inch of the water jacket..... we ended up spinning a bearing
Modified by taggart_lumpy at 2:41 AM 3/3/2007
Old Feb 26, 2007 | 01:31 PM
xsi-t's Avatar
Default Re: (taggart_lumpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taggart_lumpy &raquo;</TD></TR><TR><TD CLASS="quote">not giving you any ideas but we had a 84mm stock sleeve ls that was boosted for a bit just had block filler in about the first inch of the water jacket..... we ended up spinning bearing</TD></TR></TABLE>
B20? If not do you have pictures?
Old Feb 27, 2007 | 05:13 AM
efKART's Avatar
Default Re: (nonvtecallmotor)
81.5 is what mine would be if its .050 over? also, how big will my motor be then?
Old Feb 27, 2007 | 07:46 AM
SynTeg's Avatar
Default Re: (efKART)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efKART &raquo;</TD></TR><TR><TD CLASS="quote">81.5 is what mine would be if its .050 over? also, how big will my motor be then?</TD></TR></TABLE> .020=81.5mm which will still be a 1.86L
Modified by SynTeg at 9:03 AM 2/27/2007
Old Feb 27, 2007 | 09:20 AM
b18sihatch's Avatar
get a new block if it needs to be bored that much
Old Feb 27, 2007 | 01:00 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efKART &raquo;</TD></TR><TR><TD CLASS="quote">81.5 is what mine would be if its .050 over? </TD></TR></TABLE>
no as mentioned above... .050 inches = 1.25mm. so your motor would have a 82.25mm bore which is too big on stock sleeves. if you need to go more than .020 inches or .5mm than you should just go ahead and resleeve the whole motor.
Old Mar 3, 2007 | 01:41 AM
no pics but i promise its one of the weirdest things youve ever seen
deltahotel22
19
Mar 19, 2012 08:52 PM
hondachris1994
Mar 24, 2006 04:21 AM
awdriscol4
Nov 16, 2004 09:50 AM
USDMMARK
Feb 9, 2003 01:58 AM
DLB1994
Jun 10, 2002 08:02 PM
