want to make 250-300 hps
Old Feb 23, 2007 | 10:46 AM
Javcolin's Avatar
Default want to make 250-300 hps
Hi guys,
i have a 00 civic Si and i want to turbocharge it this is my daily ride, so i'm looking to be in the line of 250 to 300 hp. this is some of the set up i have come up with so far.
440 cc Inyectors
wallbro fuel pump
gt28r or gt28rs turbocharger
s300 hondata
hsk boost controller
300 hp intercooler.
any help or thoughts about this.
i'm plannin on spending no more than 4,000
thanks guys.
Old Feb 23, 2007 | 10:49 AM
blinx9900's Avatar
Default Re: want to make 250-300 hps (Javcolin)
you seem to be on the right path, you need a good manifold too though.
Old Feb 23, 2007 | 11:11 AM
Javcolin's Avatar
yes i saw one very nice ss for 270 shiped on the sponsors.
Old Feb 23, 2007 | 11:24 AM
Schister66's Avatar
Man U FTW
get bigger injectors....550cc at minimum
Old Feb 23, 2007 | 11:26 AM
Javcolin's Avatar
you think i need bigger inyectors?? i thought that with thosu 440's will be ok. But thats good to know. any thing else you think??
zexxbo's Avatar
Default Re: (Schister66)
yea id go with 550's or 660's. nothing bigger tho since your goals arent that big
Old Feb 23, 2007 | 11:32 AM
vtec.dc2's Avatar
Default Re: (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">yea id go with 550's or 660's. nothing bigger tho since your goals arent that big</TD></TR></TABLE>
it definatelly wouldn't hurt to go bigger. hondata should allow for stock idle and drivability.
a set of injectors - $300.
not having to replace your injectors when its time for more hp - priceless
4k? even if you get it started for under 4k, with rebuilds you're gonna be way over that sooner or later. you can save money on piping by doing most or all yourself with help of ebay. make sure the manifold/dowpipe that you choose will work with turbo that you choose.
Old Feb 23, 2007 | 11:35 AM
zexxbo's Avatar
Default Re: (vtec.dc2)
660's are good for like 400ish whp which is the most i would go if i were using stock sleeves. so if i was going to sleeve my motor and do all that build, i dont think id be too worried about selling my old injectors and buying new larger ones for my new build
Old Feb 23, 2007 | 11:46 AM
Javcolin's Avatar
They might change. but for now that what i want the mos 300 wph. since i'm not thinking of rebuild the internals. so then 550's sounds the way to go. more feed back guys!!
Old Feb 23, 2007 | 08:05 PM
Javcolin's Avatar
any other suggestions guys??
Old Feb 23, 2007 | 09:28 PM
eastbay92cx's Avatar
Default Re: (Javcolin)
for 4 grand you should be able to piece together everything new (forged rods & pistons, valvetrain turbo, ic, piping) and i would guess fuel & ecu provisions as well. this might be stretching it a little, and is not counting labor though. 250-300 on a stock engine is easily within reach for that price. shop around buy good parts and you could get away for half that.
Old Feb 23, 2007 | 10:31 PM
Javcolin's Avatar
What about if i just drop a stage 2 revhard kit with upgraded turbo to a GT28 or GT30?? would i'll be disapointed?? or is it much better to build one instead of a kit?? thanks guy appreciate all youre help.
Old Feb 23, 2007 | 11:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Javcolin &raquo;</TD></TR><TR><TD CLASS="quote">..much better to build one instead of a kit?? </TD></TR></TABLE>
yes
manifold, dp, even the other parts you can save lots $$ by buying used from the classifieds here.
make sure to take care of the ecu (crome, hondata, any of the others)
if you have the time & patience you can buy the best quality parts and teach yourself how to do it all for less than it would cost to have it done (meaning a wideband sensor w/ controller is ~$200, while dyno tuning runs ~$150/hr).
keep searching & reading, check out the classifieds is my best advice
Old Feb 24, 2007 | 10:47 AM
Javcolin's Avatar
thanks eastbay i sertanly follow your advise
Old Feb 24, 2007 | 11:04 AM
katoeh2o's Avatar
If the injector are new and you can return them at no charge I would do that. If not you will be ok. I am running 440 percison injectors. And they are doing ok.
With a t3/to4e 57trim at 9lb. on a b16.
With my stock 92 vx fuel pump I was starting to lean out at high rpm at 9 psi, but when I changed to a walbro 255 It fixed that.
But my injector duty cycle is at or over 100% at some times so This is not ideal but if you already have the injector I would run them.
But like the other guys said 300hp will bet the limit. I wish I went with 550s
budget
May 8, 2006 08:22 PM
sycamore
Nov 14, 2005 08:04 PM
deeweezy187
May 19, 2005 05:15 PM
bk11383
Jan 26, 2005 08:33 PM
LouisM
Jul 16, 2003 04:48 PM
