fule management
Old Nov 14, 2005 | 07:38 PM
sycamore
Guest
Posts: n/a
Default fule management
so im putting to geather a tubo kit for my ls turbo want to be tuned on 10 psi and it came time to figure out what i was going to do for fule management. i was thinking of hondata s200 (because i cant afford s300), just seeing what you guys would go with.
tWixT's Avatar
Default Re: fule management (sycamore)
Hmm, good question..but first, what the hell is fule?
Old Nov 14, 2005 | 07:47 PM
espanol's Avatar
Default Re: fule management (tWixT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tWixT &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, good question..but first, what the hell is fule?</TD></TR></TABLE>
give the guy a break.this isn't a spilling bee!
Old Nov 14, 2005 | 07:48 PM
sycamore
Guest
Posts: n/a
ok just had to go get my flame suit on........ fuel sorry im a retard
Old Nov 14, 2005 | 07:53 PM
tWixT's Avatar
Default Re: (sycamore)
oh ok. Here' is some nice info for you
"ENGINE MANAGEMENT- ok, you're going to need a way to deliver extra fuel to your car once it leaves vacuum and goes in to boost (more air = need more fuel obviously). there are many ways to go about this and i'm not going to go in to depth, this are requires you to SEARCH extnesively to find out how each works and what's best for your application, i'll will break it down with a 'short' summary of the most common methods.
fmu = a mechanical device that raises fuel pressure per amount of boost that it sees via a vacuum/boost source. very cheap, very unreliable, very primitive, no way to tune, very shitty. good for about 7 psi. 'safely'. not reccomended. price = $60-$100
(s/v)afc 'hack' = this is use in conjuntion with bigger injectors to deliver more fuel, you use the afc to control how much extra fuel the injectors will deliver. pretty expensive and not all that great, it advances timing and unless you use a timing retard device (which is more money spent) you have to manually retard timing at the distributor (dizzy) which causes you to lose bottom end power. a lot better than an fmu, but for the price, there are better alternatives. price = $175-$300 for afc, $40-$75 for 450cc injectors.
uberdata (obd1), turbo edit (obd0), crome (obd1) = programs are available to chip the stock honda ecu and use it as a fully tuneable system that can be compared to a stand alone system. these programs are used in conjunction with larger injectors for boosted applications. there are programs for obd0, obd1. to use an obd1 program on an obd2 vehicle, all you have to do is get an obd1 ecu (obd2 ecu's can't be chipped 'yet') and an obd2 to obd1 conversion harness. best bang for the buck by far! price = depending on your knowledge and resources chipping your ecu can cost $15-$100 and $40-$75 for 450cc injectors.
hodata, aem ems, and other stand alone systems = definitely the best way to go, but cost BIG dollars, if you have the money to spend on that stuff for your first turbo set up, you probably won't be reading this anyways.
information on engine management can be found here:
http://www.pgmfi.org
http://www.homemadeturbo.com/f...14497
http://www.ecimulti.org/uberdata/forum/
http://www.turboedit.org
http://www.homemadeturbo.com/f...14497" - Homemade Turbo
Hope that helps
Old Nov 14, 2005 | 08:04 PM
sycamore
Guest
Posts: n/a
sweet thanks a lot!
.kyle
May 31, 2006 04:49 PM
meltman1234
Dec 10, 2004 02:56 PM
Layziebtnh055
Jul 9, 2004 06:35 PM
CarbonCreations
Oct 18, 2003 11:43 AM
R-1303
Mar 5, 2002 07:42 AM
