Trannies with worn holes???
Old Feb 23, 2007 | 05:21 AM
69NOSAJ's Avatar
Default Trannies with worn holes???
My tranny alley:
I bought a couple used trannies real cheap because I'm doing a manual swap
On both of them, the main shafts bearings were busted.
***How do I get the race (sp?) out of the transmission housing w/o jackin somethin up?***(main question)***
Is the diff still good, w/ all tha rust???
Should I get new diff bearings also??? How do I tell?
Should I use anything special to clean it all up, or will brake or carb spray work?
Anything else???
Should I replace the bearing in the DX tranny and sell it?
Old Feb 23, 2007 | 06:15 AM
IN VTEC's Avatar
Default Re: Trannies with worn holes??? (69NOSAJ)
Re-install the inner race and as many of the ball bearings as you can. Wedge paper between the bearings or epoxy the bearings evenly spaced around the inner race. Knock out the bearing from the cluth bell housing side using a hammer and a 9"+ extension.
You can spin the diff bearings and if they make a lot of gritty noises when spinning them or there is excessive axial or radial play, then replace them.
Use brake parts cleaner and scotch-brite pads to clean the casing seams and dish soap/hot water to wash out the casings after you've stripped them down and cleaned the seams.
Old Feb 23, 2007 | 11:24 AM
69NOSAJ's Avatar
Thanks,
but what are you talking about using epoxy???
3rd pic, I need to get the outer race (sp?) out
Old Feb 23, 2007 | 11:27 AM
Gearspeed-Performance's Avatar
Default Re: (69NOSAJ)
Just get a small bearing puller. You may need to machine the lips a little smaller...it will come in handy! Looks like two little legs awith a lip to grab on the bearing...Looks similar to this but, with a slide hammer section like a dent puller
http://www.samstagsales.com/SirTool/st1090.jpg
Old Feb 26, 2007 | 03:51 PM
bustah49's Avatar
sell me sum parts...
any of those a hydro s80? i need a complete mainshaft and everything on it
Old Feb 27, 2007 | 04:01 AM
69NOSAJ's Avatar
p20/a000 and I'm keepin the p4a/b000
Old Feb 27, 2007 | 07:14 AM
Default Re: Trannies with worn holes??? (bustah49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">sell me sum parts...
any of those a hydro s80? i need a complete mainshaft and everything on it</TD></TR></TABLE>
Those are SOHC trans....
Old Mar 1, 2007 | 06:10 AM
69NOSAJ's Avatar
I got the race (sp?) out by welding a bolt to it and tapping it out.
I ordered a new seals and a new input shaft bearing, and hope it all goes well w/ the install. This is the first time I've messed w/ a tranny. (hahaha) It's pretty straight fwd. Are there any tricks or special instructions???
crashsvg
Jan 9, 2014 05:30 AM
s1ngle
29
May 9, 2012 03:48 PM
adubaz7
Oct 3, 2007 07:49 PM
mgags7
Sep 28, 2005 06:31 AM
LsTurbo91
Jul 16, 2002 08:00 PM
