p28 on a ITR yes or no
Old May 20, 2002 | 07:59 PM
SCsol's Avatar
Default p28 on a ITR yes or no
ok guys can i use a stock P28 ECU on a ITR motor if you only plan on driving it anound town and not shifting over 3400 rpm if i turn my fuel pressure up.
i have a chipped P28 now and im going through a tank of gas every 350 km thats shitty
i gust dont want her to run lean
Old May 20, 2002 | 10:31 PM
Sonny's Avatar
Default Re: p28 on a ITR yes or no (lowsol)
I ran a P28 on my 2000 Civic Si for about a week and didn't have any trouble. The ITR ECU will run a little richer than the Si ECU, but you should be ok as long as you don't put the hammer down.
Sonny
Old May 20, 2002 | 10:58 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: p28 on a ITR yes or no (Sonny)
if youre p28 is programmed with the correct fuel map for a type-r then you will have no problems, in fact in many cases the p28 e.c.u is the best there is
Old May 21, 2002 | 01:31 AM
Bombino's Avatar
New User
Default Re: p28 on a ITR yes or no (HOOKUPS-PRO-CRX)
hookups.. most(if not all) of the p28 compliant programs are open loop..
so you see that the map, in fact, is pretty static. Most of them dump
quite a bit of fuel. Hence, even at part throttle you will notice a drop
in MPG.
-TB
[Modified by Bombino, 2:32 AM 5/21/2002]
Old May 21, 2002 | 07:44 AM
Padawan's Avatar
Darth ModerVader
Default Re: p28 on a ITR yes or no (Bombino)
You'll also have no knock sensor.
Old May 21, 2002 | 10:58 AM
tk-Oem's Avatar
I have a stock p28 ecu on my hybrid ITR EG6. I know my car is lighter but I get 477km to the full tank on a civic. I don't know if a ITR fuel tank is any larger. Offten times I push my car to 6500 rpms and I still get 477km. So if you plan on shifting at 3400 you should at least get the same gas as I do
Old May 21, 2002 | 11:00 AM
tk-Oem's Avatar
What's up bombino? I sold the RNR's sorry bro. but I have stocks if you need them. Did you play ball on sunday
Old May 21, 2002 | 02:47 PM
Bombino's Avatar
New User
Default Re: p28 on a ITR yes or no (tk-Oem)
oh ****.. whatsup todd.. nah, no ball, I was working on car crap all day.
how much you get for the RNRs?
Hit me up via IM when you see this.
-TB
Jammersplace
Oct 24, 2004 07:35 PM
mingbling
Feb 27, 2004 10:46 AM
Vic Nyce
Apr 3, 2003 03:42 PM
