COOLANT for Turbo - Single Looped Line? One Source OK?
Hey guys
I am planning on making an addition to my factory waterneck (d16) and basically just extending out the water neck form the head about an inch so I can drill and tap a water temp port. With that space I also plan to drill and tap a hole to watercool my turbo
I was hoping I could simply drill and tap one hole for the turbo, have a single line coming off off the head, split at the turbo and each line (from the same source) go to a port on the turbo
Would this work fine? Would this flow?
Thanks
Thanks
A single line wouldnt flow. it would probably leave some air in the coolant system, plus the lack of flow could cause overheating. You'd need two lines, in and out.
PINKS
Feb 22, 2007 06:41 PM
