Help! Where is the oil pressure switch on my 1999 JDM ITR motor?
Old May 20, 2002 | 05:42 PM
JDM DC2 R's Avatar
Default Help! Where is the oil pressure switch on my 1999 JDM ITR motor?
Today I installed my complete 99 JDM ITR powertrain into my 00 theft recovery ITR.
Since I had to take off the RHD engine harness, I put a 1998 USDM ITR one on.
Everything plugged right in, except there is no oil pressure switch on my motor. I looked at the RHD harness, and there is no harness plug for it either.
Anyone know what's going on?
I do have a USDM oil pressure switch to put on, but I'm curious as to why there is one missing on this motor.
Old May 20, 2002 | 05:49 PM
Reid's Avatar
Global Moderator
Default Re: Help! Where is the oil pressure switch on my 1999 JDM ITR motor? (JDM DC2 R)
I had the same thing on a 96 JDM B18C GSR motor.
Weird.
Old May 20, 2002 | 06:04 PM
sgT's Avatar
sgT
Default Re: Help! Where is the oil pressure switch on my 1999 JDM ITR motor? (Reid)
JDM dont use it.
Old May 20, 2002 | 06:17 PM
jonnybravo's Avatar
You need an entire Vtec oil pressure assembly. Then you need to ground one side then connect the other wire to your harness.
Old May 20, 2002 | 06:19 PM
spoon_ek9's Avatar
did u get the jdm ecu also?
Old May 20, 2002 | 06:25 PM
JDM DC2 R's Avatar
Default Re: Help! Where is the oil pressure switch on my 1999 JDM ITR motor? (spoon_ek9)
yes, I did get the ECU as well... since it is a 99 ECU it won't plug into my 00 ITR so I just got a rechipped P28 with adapter harness... if I were to use the 99 JDM ECU would everything work fine then?
Old May 20, 2002 | 06:32 PM
spoon_ek9's Avatar
the 99 ecu wont plug into 00? so your wire harness is a 2 plug only type?
anyway, jdm R ecu wont look for oil pressure sersor.
Old May 20, 2002 | 07:19 PM
MiraiZ's Avatar
Default Re: Help! Where is the oil pressure switch on my 1999 JDM ITR motor? (sgT)
no oil pressure switch...
IronShogun
Aug 11, 2012 07:28 PM
PatrickGSR94
15
Aug 24, 2003 12:51 PM
PatrickGSR94
Aug 14, 2003 02:18 AM
eg6ajk
Mar 30, 2002 02:42 AM
