Fresh Built H22 Motor
Old May 20, 2002 | 04:22 PM
Mikey3000's Avatar
Default Fresh Built H22 Motor
I just got my newly built H22 to start, BUT, it doesn't stay on. it'll start for about 1 second and then die. while it is cranking on it's own, it makes a loud squealing noise, but it's a DULL squealing sound. and it's not as loud as squealing breaks. then it shuts off. this motor was built by a local machine shop. they resleeved it, put new bearings, pistons, rods, etc. does anyone have any ideas on this? i cranked it w/o spark 1st to get oil distributed everywhere. i'm fearing the worst that the cylinder liners are not true. i'm just so worried about that.....i hope to God that's not the case.
Old May 20, 2002 | 09:34 PM
PWRVTEC's Avatar
Default Re: Fresh Built H22 Motor (Boss Hogg)
Kinda sounds like too tite of clearences for the bearings, but I would have to hear it.
What happens if you give it some throttle wil trying to start it, will it run then?
Also what about when cranking it with the spark plugs out just it squeal then?
Old May 21, 2002 | 01:38 AM
Bombino's Avatar
New User
Default Re: Fresh Built H22 Motor (PWRVTEC)
thats what i was thinking too.. bearings too large.
are you using aftermarket rod bolts as well?.. and if so,
did you resize the large end after installation of bolts?
Old May 21, 2002 | 04:28 AM
Mikey3000's Avatar
PWRVTEC - if i give it gas, it'll do a little better but still shut off after about a second. when i cranked it w/o the spark plugs, i didn't hear the sound.
Bombino - i'm using the rod bolts that came with the Crower rods. i didn't install them, the machine shop did so i dunno if they resized the big end. i don't even know what resizing the big end is.
Old May 21, 2002 | 05:16 AM
John's Avatar
New User
Who did your machining?
Old May 21, 2002 | 06:01 AM
Mikey3000's Avatar
Default Re: Fresh Built H22 Motor (DunReit)
Performance Machine on Eisenhower in Alexandria.
Old May 21, 2002 | 06:31 AM
John's Avatar
New User
This seems to me that it's probably an electrical issue rather than a mechanical one. Have you checked your distributer? Are you actually getting adequate spark?
Old May 21, 2002 | 11:12 AM
Mikey3000's Avatar
i'm pretty damn sure it's getting enough spark. what i'm not sure of is if it's getting fuel. i doubt it's an electrical problem although anything's possible.
Old May 21, 2002 | 11:28 AM
John's Avatar
New User
I'm sure you've checked your fuel pump, rail, injectors, et cetera, right?
Old May 21, 2002 | 12:07 PM
Mikey3000's Avatar
yeah i hear the fuel pump turn on and i see i'm getting around 42 psi of fuel pressure at the fuel filter. what i don't know is if i have the correct injectors. is there a test outlined in the Helms that'll help me discover if i have the correct ones? i haven't found it.
user 20082082
24
Jun 11, 2009 12:22 AM
bjaccord
Nov 20, 2007 12:21 PM
metal craft
Oct 28, 2007 06:19 AM
peakboosth22
Apr 1, 2007 01:25 PM
NeriVTEC
Aug 14, 2005 05:53 PM
