D Series Clutch Question...
Well, as some of you know, I'm putting a D16Y8 into my 89 CRX, and the 89 clutch kit does not work. The pressure plate is too small, it does not bolt to the flywheel. I was wondering If I could use the y8 clutch disk and pressure plate, as well as the 89 throwout bearing with my 89 tranny. Would there be any problems with this setup? thanks!
yes it will work, you need to use d16y8 flywheel, pressure plate and clutch disk, and for using your stock 89 tranny u need to use the 89 throw out bearing.
that setup will work
will be fine since they are both D series based trannies. good luck
[Modified by poison, 4:07 PM 5/20/2002]
Yeah, I'm sure that the release bearing is different, but the clutch and pressure plate should work with the y8 flywheel, I believe, because they're all d series parts anyways. I was just looking for verification...
I thought that the y8 clutch parts would not work because it is for a hydro tranny.
the tranny he uses, and the D16Y8 will bolt up though since the tranny is designed to fit a D-series block, along with the D16Y8 won't be a problem.
I'm not sure if you have an Si or DX (I believe the Si is 5 speed, not sure though) but as for the DX, I believe it's 4 speed, and if you have the 4 speed with a D16Y8, that's gotta suck ;x
yea use your d16y8 clutch pressure plate and disk with the 89 throwout bearing. just got done putting a clutch in my wagon.i have a 94 flywheel and pressure plate with an 88 accord clutch disk and an 88 trans and throwout bearing. works great.
Nextelbuddy
12
Jan 6, 2004 05:12 PM
Thanks for the help, guys!
