Transmission grinds only when warm
Old May 20, 2002 | 12:33 PM
CivicEx95's Avatar
Default Transmission grinds only when warm
My GSR tranny grinds 3rd gear but only when the car is at normal temperature, and above 4K RPM. I tried taking it to about 6K when it was cold, and it went in with no grinding. I assume it's because the fluid is cold so thats doing something inside. I'm using Honda MTF, and I just topped it off yesterday. Is there any other "thicker" fluid maybe I can run to prevent the grinding? Other than that the car runs great. Thanks.
Old May 20, 2002 | 01:09 PM
earl's Avatar
Default Re: Transmission grinds only when warm (CivicEx95)
First try changing the fluid. Topping it off did no good.
Old May 20, 2002 | 01:23 PM
Unsung's Avatar
As you figured out, it grinds when the fluid is still cold and thick. My buddy with a B16 has the same problem. We tried friction modifier and everything -- nothing worked. We didn't try ATF however, and I heard that can fix the problem. It's just a notorious problem with B-series transmissions. Good luck. If you try the ATF, let me know how it goes.
Old May 20, 2002 | 01:39 PM
CivicEx95's Avatar
Default Re: Transmission grinds only when warm (earl)
It's a new swap so the fluid has been in for less than a month.
Old May 20, 2002 | 06:19 PM
CivicEx95's Avatar
Any other suggestions?
Old May 20, 2002 | 07:02 PM
earl's Avatar
Try a 10-30 synthetic oil. Sometimes u get lucky but sometimes the only fix is a new syncro.
Old May 20, 2002 | 08:31 PM
M-EJ1's Avatar
Yeah, it's possible that if it only does it in third that it could be your synchro. I would try out some of the suggestions in this thread first though before completely ruling everything else out.
My 2nd gear synchro is giving me grief lately. I have to be careful with my shifts or it grinds some of the time. Kind of annoying, and I really don't have the cash to pay for a new tranny or to have a new synchro put it, so I'm going easy on it for now.
Old May 21, 2002 | 12:07 AM
CivicEx95's Avatar
Cool, what about Redline MTL? That's rated at 70W80. Would that be a better option then the 10w30?
[Modified by CivicEx95, 1:07 AM 5/21/2002]
Old May 21, 2002 | 06:29 AM
earl's Avatar
70-80 is way to thick. Honda trannys are different than other gear boxes.
LLkoolskillet
Dec 24, 2010 02:40 PM
LowFlyin'
80
Oct 1, 2008 05:52 PM
tpod
Jan 4, 2007 12:49 AM
B16Jacques
Sep 15, 2006 04:06 PM
AcuraRacer112
Mar 23, 2002 01:05 PM
