tps question
Old Feb 16, 2007 | 07:55 PM
championshipwhite93si's Avatar
Default tps question
on my h22a i just recieved from hmotors, steve included a good tps for me since most if not all of them come crushed or damaged, however it is not on the throttle body.. i have heard that you have to install it with a voltage meter and get it set at a correct voltage... is that right or can i just put it in the slot and screw it in and be done with it.. just kinda curious.. thanks for any positive feedback on this guys.
Old Feb 16, 2007 | 08:35 PM
Rosko's Avatar
Default Re: tps question (championshipwhite93si)
definately adjust it and set it correctly. its not that hard to do.
Old Feb 16, 2007 | 08:36 PM
djbrandonr's Avatar
yes you need to test the voltage before you tighten it in place otherwise you get a cel. .5v w/ the TB closed and 4.5 at WOT. If you have a vfac you can test it that way too.
Old Feb 16, 2007 | 09:44 PM
Default Re: tps question (djbrandonr)
hmm i could just swap my h23 t/b since i dont have a voltage tester
Old Feb 17, 2007 | 07:17 AM
prelude_h22vtec's Avatar
yes.
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
articsilber323
Feb 23, 2010 07:28 PM
chrisfromsrq
Aug 4, 2009 04:55 PM
PHILLIPDEEZ
Jan 24, 2005 06:05 PM
hOndafienD 04
Aug 26, 2004 12:51 AM
