VAFC ques
Old May 20, 2002 | 06:01 AM
DeDonDeRosa's Avatar
Default VAFC ques
sup i have a ques for some reason when i drive my GSR and whenever i floor it the throtte percentage never reads 100 its always like in 96-97 can someone tell me why my car is doing this im kinda curious thanks alot
Old May 20, 2002 | 06:20 AM
Muckman's Avatar
Moderator in Chief
Default Re: VAFC ques (DeDonDeRosa)
perhaps your throttle cable is not tight as it should be.
Old May 20, 2002 | 04:59 PM
Default Re: VAFC ques (Muckman)
i tried the cable and its tight also it will only go to 100% when the car is on acc and not started
help me out with more ideas
Old May 20, 2002 | 05:08 PM
B18 B e a s T's Avatar
Maybe the VAFC is not accurate?? Only thing I can think of.
Old May 20, 2002 | 11:59 PM
kinesistech's Avatar
Default Re: VAFC ques (TenGrandSi)
Voltage fluctuates while the engine is running. Check your sensor voltages, and youll see the fluctuation. Its normal, every ones does it, dont worry.
Old May 21, 2002 | 05:39 AM
Default Re: VAFC ques (kinesistech)
thanks guys i will check it out but if anyone knows anything else let me know
[Modified by DeDonDeRosa, 2:48 PM 5/21/2002]
Old May 21, 2002 | 10:23 AM
RedTeg95's Avatar
When you first hook up your VAFC there is a process to set the throttle sensor in the manual. Basically the option to set it is in one of the VAFC setup menus. Just have the key in the ignition in the on position without the engine running and you press the throttle to the floor a few times so that way the VAFC learns what voltage WOT is for your car. If by chance you don't have the manual you can download it from the Apexi site.
Old May 21, 2002 | 10:41 AM
SpooN Man's Avatar
Default Re: VAFC ques (RedTeg95)
Also your Tps might be fucked up. It might not be sending out the full votlage.
Old May 21, 2002 | 10:48 AM
glock's Avatar
New User
Mine would max out at 98% or so too, then I did this and it goes to 100%
Old May 21, 2002 | 01:55 PM
B00ST2nR's Avatar
Default Re: VAFC ques (glock)
I have the solution.
Mine was at 98% also when I first installed it. I reset the ECU and tried it again. It was 100% after and everything is in perfect working condition. RESET your ecu and try again.
Old May 22, 2002 | 05:49 AM
Default Re: VAFC ques (b18c1 dc2 R)
is there a certain way i have to reset the ecu or just by disconnecting the battery and if so for how long ??
but first im gonna try the other thing so just put it to on pos and just floor it and hold it for a couple of times and this should fix it i will let everyone know after i did this
thanks guys
[Modified by DeDonDeRosa, 3:01 PM 5/22/2002]
Old May 22, 2002 | 06:11 AM
10seconds's Avatar
Honda-Tech User
my friend has the same problem on his DSM it always reads 97% and my friends with the GSR also reads 97%. Check the throttle cable. Did you install it yourself if so have someone who has put them in befroe look at it.
HondaJon
Jul 26, 2004 05:42 PM
LUDExCONDUCT
Apr 15, 2004 09:53 AM
redlinegsr
Dec 6, 2002 11:32 AM
Art Vandeleigh
Oct 26, 2002 09:14 PM
Black R
Jun 19, 2002 08:06 PM
