b20z finally here but one question
Old Feb 14, 2007 | 03:44 PM
frankie-jay's Avatar
Default b20z finally here but one question
just got my b20z from hmotoronline and by the way for everybody asking where to buy a b20z go to hmotorsonline there the best, anyway i have a 1996 integra auto and about to do some serious constrution on my car basically tranny swap and motor swap.my question is can i leave the knock sensor unpluged and have no problems running the motor cause i know my integra ls does not come with that sensor so i dont have a plug for it and second wat kind off gas r u using for the b20z due to the higher compression pistons. 87or89or91 octane?please let me know about to start swaping this thing within a week
Old Feb 14, 2007 | 04:27 PM
Default Re: b20z finally here but one question (frankie-jay)
bump
Old Feb 14, 2007 | 04:28 PM
lVlemphizStylez's Avatar
whats the compression of a b20z? I dunno how you would go about the knock sensor because even if you hardwire it, is there even a socket on the ECU that would read for it?? I dont think so on any nonvtec USDM ecu
Old Feb 14, 2007 | 04:37 PM
Default Re: b20z finally here but one question (lVlemphizStylez)
the compression is 9:6:1
Old Feb 14, 2007 | 04:43 PM
CompanyFlow's Avatar
No reason to use anything but 87 in its stock form. You think CRV owners are using 91, or 89 for that matter?
Old Feb 14, 2007 | 04:47 PM
wats the story bout the knock sensor?
Old Feb 14, 2007 | 05:47 PM
bump
Old Feb 14, 2007 | 06:20 PM
2ndgentegracer's Avatar
I have a B20B4 block in my 91 GS, didn't use the knock sensor because my ECU doesnt have one. Runs just fine.
Old Feb 14, 2007 | 08:47 PM
Default Re: b20z finally here but one question (2ndgentegracer)
To the best of my knowledge, only the B20Z's come with knock sensors.
Old Feb 14, 2007 | 10:05 PM
turbodegsi's Avatar
Default Re: b20z finally here but one question (CompanyFlow)
gsr and i belive the b16 and type-rs come with knock sensors also for the b series family it'll be fine if you dont plug the sensor in because your ecu doesn't run it..
but if you do b20 v-tec and use the v-tec ecu then you would have to run it unless you have a chip for the ecu to elimnate the sensor
it'll be ok
as far as gas any type would do as long as you stay under the 10-5 mark
Old Feb 14, 2007 | 10:06 PM
B series FTW's Avatar
about the knock sensor i think it just matters what ecu you run for a CEL light to be on or off.
Old Feb 15, 2007 | 05:31 PM
Default Re: b20z finally here but one question (turbodegsi)
I mean amongst B20's.
Old Feb 15, 2007 | 05:37 PM
My block was used in a B20/VTEC setup before I got it. It in fact did have a knock sensor.
PaChiLa Leader
May 1, 2020 07:38 AM
hondakrazy
Nov 14, 2008 10:42 AM
USDMMARK
Feb 12, 2004 08:21 AM
untitled
Aug 8, 2003 08:03 PM
civicdragger818
Jan 25, 2003 07:53 PM
