converting to obd1
Old Feb 13, 2007 | 08:40 PM
ludatic98's Avatar
Default converting to obd1
hey guys hows it goin?
anyway i am gonna get straight to the point.
i am in the middle of changing motors for a customer in a 96 prelude. it is obd 2 and i just realized that the motor he brought me to put in is obd1. the motor that came out originally was a h23a1 with a crank sensor. the motor that he brought me is a jdm h23a3 without a crank sensor.
so my question is: can i convert the car to obd1 by buying the conversion harness and a obd1 ecu? if so which ecu and harness (obd2a or obd2b) do i need?
by the way i have already swapped the intake, distributer, and original wiring harness onto the replacement motor. dont kno if this will make a difference.
thanks guys.
Old Feb 13, 2007 | 08:51 PM
mgags7's Avatar
You'll need to swap out the oil pump gear and such so you can switch the crank sensor setup to down there, or you could wire up the jdm distributor to work with internal coil.
To get the obd stuff straight, yes just an obd2a->obd1 conversion harness and an obd1 ecu will cover it
Old Feb 14, 2007 | 04:59 AM
ludatic98's Avatar
Default Re: (mgags7)
hey man thanks for the help.
bump for more info.
Old Feb 14, 2007 | 05:17 AM
kulrevon's Avatar
you can still run it as an obd2 you don't need to switch to obd1. Run the stock computer. and run a obd1 distributer. On the obd2 car the crank sensor is on the pulley on the obd1 its in the dizzy. So either wire the car to use the crank sensor thats in the obd1 dizzy which will work with your obd2 computer. Or you can install the obd2 crank sensor and oil pump on the obd1 motor.
Either method will work and both you do not need to switch to the obd1 computer.
Old Feb 14, 2007 | 05:32 AM
98vtec's Avatar
moderator emeritus
Default Re: (kulrevon)
swap the oil pumps. Rigging the wiring would create headaches in the event of an electrical failure.
Old Feb 14, 2007 | 09:25 AM
ludatic98's Avatar
Default Re: (98vtec)
changing the oil pump looks like a pain is there a write up on here for how to do it the easiest?
or maybe a write up for the distrbuter wiring?
thanks for the help keep it comming please.
Old Feb 14, 2007 | 09:27 AM
98vtec's Avatar
moderator emeritus
Default Re: (ludatic98)
im just saying...swapping the oil pumps is the CORRECT way to do it. Any other way you and you are just rigging it to work
there is a thread somehwere in the FAQ that discusses this.
Old Feb 14, 2007 | 09:39 AM
alterdcreations's Avatar
Default Re: converting to obd1 (ludatic98)
i should still have my old obd2 h22 oil pump
real cheap pm me if you want it
boobstedminime
Jun 6, 2012 09:04 AM
efrunner09
10
Sep 21, 2009 02:57 PM
vtecftw
Aug 11, 2007 11:15 AM
killerpenguin21
Jan 7, 2007 06:55 AM
mrx
Feb 25, 2005 12:36 AM
