jdm fuel gage acting up!
Old Feb 12, 2007 | 06:30 PM
rip94delsol's Avatar
Default jdm fuel gage acting up!
Well my buddy is having a problem..... with a jdm eg cluster in a 95 ex coupe
My buddy bought a JDM eg cluster for his car and knowing that no wires had to be swithced he installed it in his car..... Only bad thing is that no that clusters fuel gauge does not read... so he replaced it with the oringinal and the fuel gauge worked ****....
So he switched that jdm eg cluster for another and now that fuel gauge only reads full.....
Any1 got any advice on what to look for or something
Old Feb 12, 2007 | 06:34 PM
BlueIntegraBoy's Avatar
Default Re: jdm fuel gage acting up! (rip94delsol)
He tried two different EG6 clusters and both had the fuel gauge problem?
Old Feb 12, 2007 | 09:17 PM
Default Re: jdm fuel gage acting up! (BlueIntegraBoy)
correct! 1 fuel gauge read empty and the other full....
so on the second 1 that only read full he moved the needle down to empty hooked it back up and when he went to put in a qtr of a tank it only read full!....
so now he is like wtf because both clusters did not work!
Old Feb 12, 2007 | 09:21 PM
vtec4lyfe's Avatar
I can only assume it would then have to do with a sensor?
Old Feb 12, 2007 | 09:54 PM
Default Re: (vtec4lyfe)
okay but if the sensor is acting up how come it the stock cluster read perfect!
Old Feb 12, 2007 | 09:56 PM
beaneg6's Avatar
Default Re: (rip94delsol)
i think its his vtec!!!!!!!!! help this guy out lol...if he wants he can try my cluster!
Old Feb 12, 2007 | 09:58 PM
Maybe your friend had extremely bad luck buying two clusters with bad fuel gauges. I had a similar problem with a JDM cluster, bought a new one, and worked fine. The only reason I can think of it not working is because the cluster was tampered with. I found the reason to why my fuel gauge never worked and it was because someone tampered with the cluster.
Old Feb 12, 2007 | 11:17 PM
cxSHOE's Avatar
andre let me know if you want to borrow mine to test. bring your friends car and i'll switch them out and see. i know for a fact my gauge works perfectly fine. it could be a dirty "greenback" where it meets the plugs, see if wiping those down helps in anyway...
i tend to see alot of the jdm gauges being very dirty (copper contacts are dull has ****) compared to the usdm clusters. not sure why???
https://honda-tech.com/zerothread?id=1828273
Old Feb 13, 2007 | 06:55 AM
Default Re: jdm fuel gage acting up! (cxSHOE)
thanks/\
I will let him know right now... and see when he can do it! also when your available too....
I'll tell him to go ahead and clean the connectors and pins if he could...
buckner2009
May 22, 2009 09:08 PM
nefrideum
Jan 6, 2008 01:13 AM
EG8Master
May 23, 2007 10:44 AM
c.13
Jan 28, 2007 09:18 AM
jdmhondageek
Jan 5, 2002 06:55 PM
