JDM ITR FRONT
Long story short, I have the jdm hid front end installed and cant seem to find a good picture that shows the CORRECT way the headlights and side markers are suppose to be arranged. Every picture i have seen either the sidemarkers along with the orange marker in the headlights are always on OR just the parking and hid lights are on but nothing else. Can someone just tell me , do the side markers only come on with when turning? Also do the orange lights in the headlight always stay on?
The CORRECT way is as follows:
First click: City Lights (Fogs can now be turned on if you have the fog light switch)
Second Click: City Lights and HID
The corner lights and side markers should only come on when signaling. Hope that makes sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 »</TD></TR><TR><TD CLASS="quote">The CORRECT way is as follows:
I'v read differently, but I'm not stating these links to say who is right or wrong.
Here are the links I used to wiring my front end up:
Link 1 *scroll down*
As well as:
Link 2
-My sidemarkers are setup as running lights, (along with city lights) and the corners are blinkers.
Here is a link for a small discussion on ITR fronts, and if you would like more links I am more than happy to post them.
Discussion link
Modified by coolhandluke at 10:57 AM 2/20/2007
</TD></TR></TABLE>I'v read differently, but I'm not stating these links to say who is right or wrong.
As well as:
Link 2
Discussion link
i actually did some custom wiring...my fender side marker only comes on when signaling and my corner lights, i customized it using a dual filament bulb and harness so it comes on with the city lights and also blinks when signaling
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke »</TD></TR><TR><TD CLASS="quote">
I'v read definitely, but I'm not stating this to say who is right or wrong.
As well as:
Link 2
Discussion link </TD></TR></TABLE>
Your post is a little confusing to me...I can't tell whether or not you're agreeing with me. But the way I posted above is the way they came from the factory...the corner lights and sidemarkers should only be on when signaling...NOT as running lights.
As well as:
Link 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radio1global »</TD></TR><TR><TD CLASS="quote">Whats the dual filiment bulb number?</TD></TR></TABLE>
Which bulb are you asking about?
Your post is a little confusing to me...I can't tell whether or not you're agreeing with me. But the way I posted above is the way they came from the factory...the corner lights and sidemarkers should only be on when signaling...NOT as running lights.</TD></TR></TABLE>
Sorry, my post was confusing. I had some typo's and they have been corrected.
From: ...and then along comes the fcuking policia, PA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura »</TD></TR><TR><TD CLASS="quote">wat exactly r city lights?</TD></TR></TABLE>
first of all use proper grammer
second, a city light is a small bulb in the headlight housing that comes on with the parking lights that emits a "glow" from the headlight area for when the use of the actual headlight isnt needed but the visibility from other drivers is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attentionwhore »</TD></TR><TR><TD CLASS="quote">
second, a city light is a small bulb in the headlight housing that comes on with the parking lights that emits a "glow" from the headlight area for when the use of the actual headlight isnt needed but the visibility from other drivers is.</TD></TR></TABLE>
Or grammar...?
To JDMsta's innovation, pretty cool.
Or grammar...?
