HELP>>>PLEASE!!!
Old Feb 11, 2007 | 09:36 PM
IntegraGSR-Turbo's Avatar
Default HELP>>>PLEASE!!!
ok need to know bad...i have a b18c1 block...i have ls pistons in it just found out yes they are pr4's...HOW DO I TELL THE DIFF BETWEEN A GSR CRANK AND AN LS CRANK..is there any marking
Old Feb 11, 2007 | 11:50 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: HELP>>>PLEASE!!! (IntegraGSR-Turbo)
Not sure, but I will bump for you to get help. My GSR crank is kinda in the motor for me to look at and compare, but I have an LS crank on a shelf in the garage I can compare to someone on here if there is any help?
Old Feb 12, 2007 | 09:53 AM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Default Re: HELP>>>PLEASE!!! (SlammedDC2)
I'm not sure, bump for you.
Old Feb 12, 2007 | 09:54 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: HELP>>>PLEASE!!! (Code)
Anyone have a GSR crank out of the car that we can compare to my LS crank??
Old Feb 12, 2007 | 02:49 PM
VTEC420's Avatar
Mines still in the block but the block is out of the car. I can see most of it though. If you post some pics and or ask specific questions I can take a look. Otherwise I'll have some time to pull the crank out in a couple days...
Old Feb 12, 2007 | 03:38 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: HELP>>>PLEASE!!! (VTEC420)
I have a shitty camera, but I will go out in the garage later on tonight and take some pics
Old Feb 12, 2007 | 03:46 PM
poorman's type-r's Avatar
* B A N N E D *
only way for me to tell if it was a GSR or LS crank was to get a LS rod and put it in the rod journal and see if it fit or not. if it does then it's a LS crank. if it doesnt fit then it's a GSR crank. B16 and LS crank have the same rod journal size (correct me if i'm wrong.) B20 uses the same crank from the LS too, just different piston. GSR/Type-R have the same rod journal size. another way to check is by measuring the rod journal size which i forgot what size they were.. haha.. i remember there was a 2mm different from the rod journal, LS/B20/B16 being the 2mm bigger then gsr/type-r...
Old Feb 12, 2007 | 09:34 PM
Default Re: HELP>>>PLEASE!!! (poorman's type-r)
ok thanks and my question can you use pr4 pistons on p72 rods then..cuz if you can i prob have the gsr crank
Old Feb 12, 2007 | 10:12 PM
ObeyDB8's Avatar
cant help but bump!
Old Feb 13, 2007 | 02:18 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks and my question can you use pr4 pistons on p72 rods then..cuz if you can i prob have the gsr crank</TD></TR></TABLE>
yes you can use pr4(LS) piston on gsr(p72) rod. but why would you unless you're going F/I because it going to drop your compression down...
Lil_savage
Feb 20, 2019 03:19 AM
TurboCivicR93
Aug 18, 2012 02:33 PM
helpmycivic
Dec 9, 2009 08:23 AM
allmotorek8
Nov 15, 2007 08:05 PM
SoSlo
Dec 9, 2006 05:15 PM
