how to remove driver side mount bracket?
Old Feb 11, 2007 | 01:39 PM
invisible's Avatar
Default how to remove driver side mount bracket?
i got the two bolts underneath it but its not coming off. is anything else i need to take off?
Old Feb 11, 2007 | 01:40 PM
92ehatch's Avatar
Default Re: how to remove driver side mount bracket? (.hue)
yeah, there is a bolt on the end of it..then you need to unbolt the ac/ps bracket from the block to give you a little clearance
assuming this is a 92-95
Old Feb 11, 2007 | 01:42 PM
invisible's Avatar
Default Re: how to remove driver side mount bracket? (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah, there is a bolt on the end of it..then you need to unbolt the ac/ps bracket from the block to give you a little clearance
assuming this is a 92-95</TD></TR></TABLE>
well its on a gsr, but i thought it would be the same as a si.
Old Feb 11, 2007 | 02:08 PM
sicones's Avatar
there's 3 bolts, and exactly what part of the mount are you trying to remove
what engine/year/car??
Old Feb 11, 2007 | 02:41 PM
invisible's Avatar
Default Re: how to remove driver side mount bracket? (sicones)
1994 gsr motor. i need to remove the mount to replace it with the 99-00 si one.
Old Feb 11, 2007 | 02:48 PM
Civichx1998's Avatar
there are 3 bolts in a triangle pattern 2 on the top 1 on the bottom you might have to remove the plastic for the timing belt guard to get to the bottom one.
Old Feb 11, 2007 | 03:44 PM
invisible's Avatar
Default Re: how to remove driver side mount bracket? (Civichx1998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichx1998 &raquo;</TD></TR><TR><TD CLASS="quote">there are 3 bolts in a triangle pattern 2 on the top 1 on the bottom you might have to remove the plastic for the timing belt guard to get to the bottom one.</TD></TR></TABLE>
how do you remove the lower plastic cover?
Old Feb 11, 2007 | 05:47 PM
sicones's Avatar
are you trying to do an engine swap or something, taking those covers off are pretty self explanatory, figure it out
Old Feb 11, 2007 | 05:54 PM
invisible's Avatar
Default Re: how to remove driver side mount bracket? (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">are you trying to do an engine swap or something, taking those covers off are pretty self explanatory, figure it out </TD></TR></TABLE>
yeah need to get the bracket swapped over first haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">
remove the crank pulley, remove all the 10mm bolts, and remove the top timing cover also</TD></TR></TABLE>
gotcha thanks
Arthas
Jul 23, 2010 01:38 PM
invisible
Feb 11, 2007 05:50 PM
Integra4106
Sep 8, 2006 10:33 AM
.Radical_Edward.
Jun 9, 2006 08:11 PM
ZUL8R
May 20, 2003 06:24 PM
