Will a H22a work in DX/CX/LX civic??
Old Feb 11, 2007 | 06:58 AM
HondaH22a#1's Avatar
Default Will a H22a work in DX/CX/LX civic??
I need some serious help. I an buying a 1994 DX Civic coupe and want to put a H22a motor in it. I have never done a motor swap before. A lot of people are telling me that this is very hard to do but I really want to do it. I need some serious help from someone who knows their stuff!
Old Feb 11, 2007 | 07:02 AM
Eran's Avatar
HT White Ops
Yes, it will work. Pay a shop to get all the parts do all the labor.
Old Feb 11, 2007 | 07:20 AM
JDM_EK_wanabe's Avatar
Default Re: Will a H22a work in DX/CX/LX civic?? (HondaH22a#1)
H22 swaps are definatly not for the first time swaper, if you want it done right get a well know shop to do it, otherwise do a B series swap, its alot easier and beter for a first timer, and also look in the sticky, they have almost everything you would want to know and do to your car, espescially(sp) engine swaps, or check out the hybrid area, they have a lot of H22 swap info there
Old Feb 11, 2007 | 07:27 AM
MJ0LNIR's Avatar
Your search for h22 swap returned 128 results.
Here's some to get you started...
https://honda-tech.com/zerothread?id=362984
https://honda-tech.com/zerothread?id=650329
Never done it, but all I've read indicates that it can be done, just a little more challenging. Up to you to determine your skill level, either you're in over your head or you're about to learn something.
Old Feb 11, 2007 | 08:01 AM
WhiteOnRice's Avatar
There are enough write ups out there that the H swap isn't much harder than a B. Slightly bigger, the shift linkage conversion, and getting all the parts you'll need.
Old Feb 11, 2007 | 08:59 AM
Syndacate's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it will work. Pay a shop to get all the parts do all the labor.</TD></TR></TABLE>
I don't particularly agree.
An h22 swap is harder than D and B swaps - but very far from a HARD swap.
If you have a car you can drive while you do the swap I'd say go for it. If not, i wouldn't.
Just take your time, go through it piece by piece, and you'll find it's a really good learning experience. H22's are fun .
If you don't have another car to drive I wouldn't recommend it as if you've never done a swap before and nobody's helping you and if you want to do things right it can take some time. And if you're doing it in a driveway or garage instead of a shop or something w/ a lift and engine hoist etc. it can take longer.
The only thing I can recommend is that you study H22 swaps and KNOW what you're getting into FINANCIAL wise. The H22's not too expensive, but its usually the side pieces like the mounts that start pumping up the cost.
Don't buy from Hmotors.com either - buy it locally. 2k for an h22 is stupid as **** (plus that's w/o shipping). You can probably pick up a totaled prelude for like 500.
Old Feb 11, 2007 | 09:58 AM
Eran's Avatar
HT White Ops
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
You don't agree that someone who is not mechanically inclined and has never done a motor swap should pay someone else to do their swap?
Ok, I hope you're on call to help this kid every step of the way through his engine swap, through every wire, sensor, cut, solder, frame notch, axle selection, and every other problem he's going to post every fifteen minutes for a week straight.
Old Feb 11, 2007 | 10:22 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (Eran)
an h swap bolts in, you wanna know what a hard swap is????????
an ls1 into a civic hatch, mid engine reardrive, now thats hard
Old Feb 11, 2007 | 10:47 AM
Eran's Avatar
HT White Ops
Default Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">an h swap bolts in, you wanna know what a hard swap is????????
an ls1 into a civic hatch, mid engine reardrive, now thats hard </TD></TR></TABLE>
Hard is relative. I'm far more likely to be able to put an LS1 in a civic than my mother is to put a D16 into a civic. If this guy doesn't know what he's doing, then he probably shouldn't do it.
Old Feb 11, 2007 | 11:01 AM
allricedout's Avatar
just study those links provided and see if its something you can handle.
Old Feb 11, 2007 | 11:06 AM
Red_Octane's Avatar
What about a F series? Like F20 or F22 or something like that...would those be a plug and play in a DX?
Old Feb 11, 2007 | 11:21 AM
Eran's Avatar
HT White Ops
Default Re: (V_Razr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V_Razr &raquo;</TD></TR><TR><TD CLASS="quote">What about a F series? Like F20 or F22 or something like that...would those be a plug and play in a DX?</TD></TR></TABLE>
No. You have to change mounts, custom wiring, etc.
Modified by Eran at 12:55 PM 2/11/2007
Old Feb 11, 2007 | 07:46 PM
* B A N N E D *
Default Re: (Eran)
f20-harder
f22 i belive same mounts as h22 correct me if im wrong but why waste time on an f22?
Old Feb 11, 2007 | 08:34 PM
muhaMan's Avatar
i heard that if you put a h22 in a lightweight Civic then you get HORRIBLE handling.. is that true??
Old Feb 11, 2007 | 08:39 PM
JDMH22HATCH's Avatar
Default Re: (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan &raquo;</TD></TR><TR><TD CLASS="quote">i heard that if you put a h22 in a lightweight Civic then you get HORRIBLE handling.. is that true??</TD></TR></TABLE>
No, that is not true. Its been an ongoing myth for years. There is such a large selection in suspension products with custom valving and spring rates that you can make it handle however you want. Plus the H-series is only 40lbs more than a b-series.
95_civic_hatch
Mar 25, 2008 10:12 AM
BigHeadKid
20
Jan 3, 2005 09:14 PM
civic01mtx
Jul 8, 2004 12:49 PM
97emsedan
Jan 21, 2004 09:44 AM
compwc18
Feb 8, 2003 05:58 PM
