Eg coupe w/ gsr motor
I have a eg coupe and im going to drop in a jdm gsr motor. the previous motor was turbo single cam which blew, anyways will the sohc vtec engine harness obd1 work with a obd1 gsr motor?
I also would like to know if i can use stock gsr mounts and do i need to use integra axles?
You can use the EX harness with modifications (adding knock sensor and IAB). You use all Integra brackets and mounts but keep the Civic rubber mounts. You will use Integra axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You can use the EX harness with modifications (adding knock sensor and IAB). You use all Integra brackets and mounts but keep the Civic rubber mounts. You will use Integra axles.</TD></TR></TABLE>
so i cant use 1994 sohc vtec civic coupe harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">
so i cant use 1994 sohc vtec civic coupe harness?</TD></TR></TABLE>
read what he just posted: you CAN use your stock engine harness with modifications: addition of three wires: knock sensor(1) and the IAB aka secondary butterflies(2).
for the IAB hook up the positive side to a positive wire on the engine (any yellow and black wire will do) and on the negative ground to chassis or engine ground (thermostat housing, etc...)
BTW in addition you need to get any type B series engine axles and the intermediate piece too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">
BTW in addition you need to get any type B series engine axles and the intermediate piece too. </TD></TR></TABLE>
ok thanks. god knows where the expletive im going to find someone to re-wire stuff for the 3 things listed above.
also if i was to buy innovative mounts, do i need to buy the 2 bolt pattern or 3 bolt pattern?
http://passwordjdm.com/product...D=467
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">also if i was to buy innovative mounts, do i need to buy the 2 bolt pattern or 3 bolt pattern?
http://passwordjdm.com/product...D=467</TD></TR></TABLE>
You need the 3 bolt like this one: http://passwordjdm.com/product...D=467
BTW you can still reuse all of your stock mounts unless you plan to go road racing, drag,
auto cross, etc...
The only part you really need is that rear mount bracket which you can get from any b-series engine integra or del sol VTEC.
auto cross, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">BTW you can still reuse all of your stock mounts unless you plan to go road racing, drag,
auto cross, etc...
The only part you really need is that rear mount bracket which you can get from any b-series engine integra or del sol VTEC. </TD></TR></TABLE>
but if i use stock gsr mounts w/ inserts do i still need the rear mount bracket?
auto cross, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">also if i was to buy innovative mounts, do i need to buy the 2 bolt pattern or 3 bolt pattern?</TD></TR></TABLE>
it will be the 3 bolt pattern
gl with your swap!!!
E36 Guy
Aug 26, 2005 07:02 AM
b18cInside
Dec 10, 2002 09:02 AM
