GSR brake/supension swap
All 94+ integra brakes (minus itr) are the same....
If you have the ex/si/abs knuckle (10" rotors) the calipers bolt right on.
All rear disc parts are identical (minus da/ef which have larger bushings)
Search in places other than the FAQ, this has been coverd again and again and again
Yes you can. Just keep the EK upper control arms in the front. I think thats what they are called. It holds the top ball joint for the knuckle to bolt in. Make sure you use the EK one. I just did this and it worked perfect.
sj-performance
Jul 14, 2009 07:55 PM
lowgman
Jan 16, 2005 07:19 PM
ncVTEC1313
Jun 3, 2004 05:14 PM
