Alternator
Old Feb 6, 2007 | 06:25 PM
honda94accord's Avatar
Default Alternator
I have a system in my car. And aftermarket lights and such hooked up on my car. And i can't help but notice my lights are really dim when sitting. but the second i hit the gas they get bright. And when i apply the brakes. They seem to almost go out. If i put a higher amp alternator on my car would that help this problem? And get rid of the lights dimming and such? Cuz it is really annoying me, im picky about that stuff.
Old Feb 6, 2007 | 06:27 PM
YeuEmMaiMai's Avatar
Default Re: Alternator (honda94accord)
first off load test your system to make sure that it is the alt and not a bad battery drawing down your load at idle.
what exactly do you have installed in your car?
Old Feb 6, 2007 | 06:37 PM
Bruce Banner's Avatar
Default Re: Alternator (YeuEmMaiMai)
2nd the load test
Old Feb 6, 2007 | 07:11 PM
Default Re: Alternator (Bruce Banner)
Brand new battery. Not even 6 months old. And im running a 1000 watt amp. Higher wattage headlight bulbs. Halos in my headlights. And some interior Lights.
Old Feb 6, 2007 | 07:14 PM
put in a 1 farad cap to help feed your amp and load test the system before and after....any time you are sucking major wattage you need a cap to help with the energy drain......most likely need a higher capacity alt. try using one from the 4cyl oddessy
Old Feb 6, 2007 | 07:21 PM
I was planning on buying a cap. And does it really matter what kind? Like company or quality? And do u suggest trying to find an alternator off an odyessey? or could i just buy a higher output one from somewhere else?
Old Feb 6, 2007 | 07:34 PM
AJ06's Avatar
A cap wont [in theory] help much with the voltages, as it needs to be changed by an already potentially weak alternator, your best bet is a new HO [high Output] alt and upgraded wiring.
I did that and it helped me tons
Old Feb 7, 2007 | 09:39 AM
sony224422's Avatar
Default Re: (AJ06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ06 &raquo;</TD></TR><TR><TD CLASS="quote">A cap wont [in theory] help much with the voltages, as it needs to be changed by an already potentially weak alternator, your best bet is a new HO [high Output] alt and upgraded wiring.
I did that and it helped me tons</TD></TR></TABLE>
true. but i doubt he has a 1000 wrms amp, its probably 500ish and doesn't need a new alternator. a cap will be enough for his headlights to stop dimming. i have 850 wrms and a 1 farad cap and have almost no dimming even sitting still with the air on.
ejfromwestbay
38
Nov 29, 2011 07:13 PM
AsianCivicRider
Nov 9, 2011 06:43 PM
JDMgareth
Sep 27, 2007 02:00 PM
Ziggie
Audio / Security / Video
Aug 25, 2003 07:55 AM
